My whole car is shaking after 40 mph, ive tried everything..
#63
So I fixed the problem... I was driving back to Houston, vibrations and all, when I hear a loud hiss. My front passenger tire blew out. I took it off and saw that there was a slit about 2 inches long near the top of the sidewall where the tread is. I put on my oem 17" spare and vibration was noticeably reduced. I texted my friend and he said that it was probably a bubble that caused it to vibrate and that I also needed a balance. Took the wheel to a shop when I got back and they mounted/balanced the tire and wheel and vibrations gone! Glad I dont have to deal with the headache of messing with the suspension to figure out what the problem was... at least not now :P
#64
i had the problem when i first bought my GS , went ahead and replaced lower inner/outter tie rod ends and bushing. Daizen steering rack bushing is a must. i also went with Megan LP Flawless and did my alignment and also road force balance rims/tires. Last thing i did was turn the nut for steering rack. Took it 0 -100 flawless no shakes at all.
Let me know if you have any questions.
#66
sounds like it is not balanced to zero! i had the same problem and everytime id balance with a different place they werent balancing exactly to zero. if its off a pubic hair it will make your car shake!
TRULUX
Suspension and Brakes
07-20-05 07:39 AM
