My whole car is shaking after 40 mph, ive tried everything..
Old 07-07-09, 11:57 AM
BIGVIC23
BIGVIC23's Avatar
Default My whole car is shaking after 40 mph, ive tried everything..
So heres the story: i have 20s and have lowered H&R springs, and have had it for around 2 years. For the last year the steering wheel and the rest of the car has been shaking alot. Obviously, like everyone else, its at its worst at 60mph, but can still be felt alot at 90mph..
... last week i changed: the two front ball joints, two front outer tie rods, had two different wheel alignments, rotors, brand new balanced tires, and nothing has changed. Can someone give me some advice? i know it might be the rims or the steering needs to be adjusted. Is there anything else i could check or change? Its really frustrating because i feel like im driving an old pickup truck.. Thanks in advance
btw... my right front axle is missing a lug... i dont know if that has anything to do with it
Old 07-07-09, 12:34 PM
GS300ToM
GS300ToM's Avatar
missing lug, that will do it!!!!!! but check your wheels road forced balance to see if they are bent or out of round... read up on my thread.. this should help alot
https://www.clublexus.com/forums/gs-...mph-after.html
Old 07-07-09, 01:13 PM
kit cat
kit cat's Avatar
definitely put on a matching lug nut.
Try putting back on the stock wheels and stock lugnuts for a day and see if the shake is gone. If it does, it would imagine its the wheel....Lexus has lug centric wheels. Your 20" wheels are most likely not.
Old 07-07-09, 01:42 PM
BIGVIC23
BIGVIC23's Avatar
where can i get that done?
Old 07-07-09, 01:44 PM
BIGVIC23
BIGVIC23's Avatar
yea switching out the wheels are the next step, when i have time.. but yea i have the hubcentric rings... btw can plastic hubcentric rings (from ebay) warp?
Old 07-07-09, 02:17 PM
GS300ToM
GS300ToM's Avatar
call any shops thats around your area and ask if they have a road force balancer
Old 07-08-09, 09:13 AM
Infamous 1
Infamous 1's Avatar
Also try replacing your steering rack bushings and control arms bushings if all else fails. Good luck!
Old 07-12-09, 09:45 PM
BIGVIC23
BIGVIC23's Avatar
Update:: So i just replaced my stock rotors with some drilled/slotted ones from ebay... and also swapped the broken lug out with a new one...
still shakin... i guess that means the next step is the daizon steering rack bushings, and getting the wheels road force balanced....
btw... can people tell me where they got theres done? and how much was it???
Old 07-15-09, 10:21 AM
BIGVIC23
BIGVIC23's Avatar
(UPDATE)
ok... i just swapped the front 20s with my stocks and theres only a slight change. It still shakes alot and is still very annoying. the only thing else to do is the bushings and adjusting the steering... is there anything else? whats making it shake so much??
Old 07-15-09, 10:37 AM
GS4_Fiend
GS4_Fiend's Avatar
Bent wheels...
Old 07-15-09, 11:41 AM
BIGVIC23
BIGVIC23's Avatar
Originally Posted by GS4_Fiend
Bent wheels...
i have the same problems with my 20s and my stock 16s... both cant be bent... i hope
Old 07-16-09, 11:27 AM
BIGVIC23
BIGVIC23's Avatar
...........anything?
Old 07-16-09, 12:39 PM
GS300ToM
GS300ToM's Avatar
Check your bushing and try the steering rack method
Old 07-16-09, 01:37 PM
GS4_Fiend
GS4_Fiend's Avatar
I suggest you take your wheels to a tire place. As they are balancing them. Ask them to watch to see if the wheels are bent by looking at the wheel spinning. That's how I found my culprit. One of my front wheel was slightly bent, which cause vibration on the freeway. Hope that helps. Just speaking from experience.
Also if you have spacers, that could be another culprit too.,
Old 07-17-09, 08:34 PM
BIGVIC23
BIGVIC23's Avatar
(update)
so i just ordered the steering rack bushing kit, so we'll see how that goes....
monday im taking the lex to the dealer to get a pro to look at it....
and last but not least what are the symptoms of a bad upper control arm?
Quick Reply: My whole car is shaking after 40 mph, ive tried everything..
