Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
- Lexus IS GS: How to Change Disc Brake Pads
Step by step instructions for do-it-yourself repairs
IS250 rear brake replacement (GREAT DIY with lots of PICS!)
#46
If your sliding pin was jammed up, would your ebrake still work?
My old car had the rear calipers freeze up all the time, but I also didnt have an ebrake
hooked up to them to exercise them. I heard that you're supposed to use the ebrake often to keep things working, not sure how true it is though.
#47
I had the same problem with the seized pins on the rear calipers and ended up replacing them with new OEM ones that were about $200 each. I kept the old ones and will use them as my core when I have to replace them the next time. I'll probably go with remanufactured ones next time. ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
One other thing, if you're just replacing your brake pads, there's no need to have to remove the caliper. You can just remove those springs, pull the 2 pins out and the old pads will slide right out.
#48
dont you guys just compress ur callipers before taking out the old pad with a c clamp just like the front brake diy....
https://www.clublexus.com/forums/sus...g-caliper.html
#49
Tech Info Resource
#50
I too have experienced difficulty in reinstalling the rear outer pads on my wife's is250.
I have found that by using penetrating oil on the lower "pin"- the one the entire caliper will (should) rotate on, allowed me to wiggle the caliper off. That's why the outer worn pad will likely be much thinner than the inner. The design is supposed to allow the caliper to float on those large guide pins. The upper guide has a hex head and the lower guide does not. When I finally removed the first caliper, it all began to make sense. I got everything cleaned and lightly greased the lower mount pin and the upper mount pin/bolt. I now had the needed clearance to install the outer pad!
Hope this helps.......
#51
#53
Hey, any type of penetrating oil will work. BE VERY careful not to contaminate the rotors or the new pads upon reassembly. wipe/spray rotors with brakecleaning spray before caliper reassembly.
Cesar@623.225.9817
Cesar@623.225.9817
#55
I bought the Akebono pads and Centric premium rotors from Tire Rack and they are fantastic. They come assembled with the shims, so NO cleaning the old ones and then hassling with which one goes where and which way. They also come with a foil pack of grease! They DON'T squeek, and there is NO DUST....the fronts look AND STAY just as clean as the rears!!!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
And BTW, thanks for the write up.
(Also worth noting: while setting the brake pads I did reach the point of mild fade after repeated full pedal stops from 60 to 5mph, but the stopping power is excellent for normal driving. (I was a little concerned about their 2 "dot" rating on stopping power, and I would agree for track use they are not suitable, but for normal street driving they are fine. This is my wife's car, and I wouldn't use anything that I didn't consider very SAFE. (but I did just increase her life insurance) jk
#56
Is there a link to where I can find the pics? They're not loading properly. Or is it just me..![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I am having trouble getting the slider pins out so I can remove the brake pads, and was hoping I could maybe see what people are doing differently, so that I can learn.
Thanks!
Thanks!
#57
Does anyone know if there's a recall on the rear caliper pin? Or anyway to remove the pin and grease it cause I've install new rear pads on and the driverside pad was to tight cause the pin would not move freely.
