Camber adjustment with no Camber Kit ?????
I just rectenly installed a set Hotchkis Springs. drop is 1 1/2 front and 1 in the rear. The car drives straight, but It looks like there might be a little negative caber. I installed the springs myself and I noticed both front and rear suspension have a bolt that looks like its made to adjust the camber. If I take the car to get aligned can they adjust it without me having to get any camber kit.
![](http://img.photobucket.com/albums/v486/nycgts/img1248126998150.jpg)
Tech Info Resource
Yes. Camber is adjustable from the factory.
Thank you. I figure that, but then I go around reading forums and most just mention to get the camber kit. I think for a small drop I dont need to spend so much money on a kit.
thank you again. I will tet my car aligned in about two more days.
