Tein CS Coilovers
Old 04-06-02, 05:51 PM
MRGS400nSoCali
MRGS400nSoCali's Avatar
Default Tein CS Coilovers
Just got my Tein CS Coilovers installed on my 98 gs400 after 4 long hours of work with a buddy. I got it aligned the very next day as the alignment was WACK after the install. I set the coilovers on the softest setting but seems to be a little too soft for me (a little bit softer than stock). Anyone have any suggestions on how many CLICKS i should go with front and back. Thankx
Martin
Old 04-07-02, 04:53 PM
LXOGOOD
LXOGOOD's Avatar
I would like to know also because this is my next mod for the car in May.
Old 04-08-02, 09:14 AM
ivc
ivc's Avatar
I did install the CS too roughly a month ago, but I can't feel any difference from the softest and the hardest setting. My friend told me its because there is no much space to travel for the shock since I adjust the coilovers to the lowest possible height. Anyway, anybody out there know how to adjust the coilover even lower than the the lowest height?
Old 04-08-02, 11:40 PM
Manaray
Manaray's Avatar
Martin - You just have to try it out and see for yourself...what someone else thinks is "OK" may not be OK for you...generally, the fronts are set stiffer than the rear...
ivc - there is no way to set it past the lowest setting because you have no threading left...the only way to do it is to have the shock body threaded some more...
Old 04-09-02, 11:08 AM
ivc
ivc's Avatar
I have thought about rethreading it a little further, but what I'm afraid is, is there enough space for the shock to travel? Do you by any chance know the shock travel left after I set it in the lowest height? I'm worried that if I rethread it more, it will often hit the bump stop every time I hit a small pothole...
Thanks.
Old 04-10-02, 12:39 AM
Manaray
Manaray's Avatar
Unfortunately, I can't answer that question. You could TRY sending Tein some email...dunno if they'll respond though...the USA office seems rather clueless...
You could always just TRY it and if it does bump, then just move it back up....if I had to GUESS, I would say it wouldn't be a problem.
Old 04-10-02, 09:53 AM
LXOGOOD
LXOGOOD's Avatar
ivc- how much of a drop is your car right now at the lowest setting? 1.5", 2.0", 2.5".
Old 04-10-02, 10:57 AM
ivc
ivc's Avatar
I don't remember the exact height when the original shock and spring is still in use, but I'm pretty sure it is roughly 2.5"
The front still has a gap the size of maybe a pinky. And the back tires are covered by the fender roughly a pinky. That's the lowest possible height. Each of the coilover has 2 big nuts for adjusting the height and locking it in the middle. I have thought that since I put it in the lowest setting, I could just remove 1 of them and getting it further lower by 0.25"
But eventhough I want them to lower more, I could feel that the bumper can easily hit the floor, especially when I go into people's driveway, just have to drive diagonnaly.
Old 04-10-02, 05:46 PM
LXOGOOD
LXOGOOD's Avatar
WHoa, that's a pretty huge drop. Have you thought about going to 19's or even 20's. That would help get rid of the wheel gap without a huge drop in suspension.
I can't wait to get TEIN's. I need to lower my front more due to the weight of my speaker box in the rear which is causing my back end to sag a little. Right now I have a 1" drop all around. I need at least a 2.0" drop up front with a 1.4" in the rear to even out.
Old 04-10-02, 07:59 PM
ivc
ivc's Avatar
Are you getting the HA or CS? I am really happy that I get the CS, because after putting it in the lowest height, the ride is still very nice. A little harder, but just a little, its actually better. For roughly 2.5" drop, that comfort is, I would say awesome...
Old 04-10-02, 08:39 PM
Manaray
Manaray's Avatar
IVC, if you have it that low already, I wouldn't try to lower it any more. And DO NOT take out the lock ring....you're suspension can SHIFT w/o it...what's wrong with the way it's set now? Sounds perfect...
Old 04-11-02, 09:54 AM
ivc
ivc's Avatar
Maranay: Thing is, the front still has a small gap. I wanted at least the tire being covered by the fender a little bit, not too much. I have thought of getting bigger wheels, but that cost a lot of money. Regarding the shifting suspension that you mentioned... I still don't understand how it can happen. For instance, if I remove the lower ring, move the upper ring further down 0.25" and tigthened it against the last thread, wouldn't it be the same actually? Maybe I'm missing something here. The only concern that I have, is 1 ring strong enough to support the weight of the car, versus 2 rings.
Thanks.
Old 04-11-02, 07:08 PM
LXOGOOD
LXOGOOD's Avatar
TEIN CS for sure. It's all about looks and comfort for me. I had my fun with power and suspension in my last car. A '97 S.C Z28.
Old 04-11-02, 10:59 PM
Manaray
Manaray's Avatar
ivc - Here's the deal...the bottom ring is a lock ring, it keeps the upper ring from moving. Now if you remove that ring, the threads on the upper ring will lock against the body of the shock. HOWEVER, the constant vibrations and load can push the ring PAST the threading (try it out with some threaded PVC pipes...it's not really hard to do)...if that happens, your front or rear end (depending on which side you did it to) will COMPLETELY COLLAPSE. Do you really want to run that risk while you're driving your car at 75MPH on the freeway just to get a extra .25"? Is your life and/or the life of others worth it?
Just get bigger wheels...18's look small on a GS anyways!
Old 04-12-02, 07:30 AM
ivc
ivc's Avatar
maranay: hhhmmmm... now it does make sense... thanks for the advice... I'll try to save more money and get a bigger wheel in the future then...
Thanks.
Quick Reply: Tein CS Coilovers
