Anybody know if these will fit my rims?
Hey guys ive had my sc for about 2 years now and i just got on the forum because i know a lot of you guys have the ls400bbk on your sc and im thinking about doing. I have is300 oem rims on my sc. Would the ls400 calipers fit with them???
The IS300 wheels will not work with the LS400 bbk. The only OEM wheels that I know of that will work with the LS400bbk is SupraTT and LS400 wheels. As a general rule of thumb you will need about 2.75in of clearance from the rotor face to the inner spoke of your wheel. Running spacers on your IS300 wheels might do the trick. Good Luck
Probably at least 20mm spacers. I believe stock offset on the IS300 wheels are +55 and +50... I know some IS300 comes staggered like 17x7.5 and 17x8.5 or maybe 17x7 and 17x8... If they are all 17x7 then it will be +55 offset
justinp95
Wheels, Tires & Brakes Forum
03-23-10 02:10 PM
