Can you buy just a rear sway for GS?
Registered User
Guys, I'm new to the world of GS. Can a rear sway be purchased by itself? So far, I've only seen it offered in a pair with the front.
Also, what sites besises Carson Toyota sell performance for the G?
thanks in advance!
thanks in advance!
Your car does have (stock) sway bars already front and back. Why would you only want to replace the rear one?
Registered User
less body roll, it helped significantly on my Maxima, .....but that could be because its front wheel drive......maybe.....I just need to put a larger sway on the front for flatter cornering and reduced oversteer........ ---just thinking out loud here----
Registered User
My second post says "thinking out loud" which is what I was doing. I have since decided to go JUST for a front sway. You see, replacing them individually allows you to tune the cars handling characteristics. Replacing them in pairs will make the car handle better, but if it has a problem with oversteer when stock, guess what, it will handle better, but still oversteer at the breaking point. Replacing just the front bar with a stiffer bar should make it handle better and reduce the tendency to oversteer to a degree.
My other car, the Maxima, understeered like crazy, I just put on a rear sway bar and it greatly improved handling balance--it does not understeer NEARLY as badly. Again, custom tuning. I hope this makes sense. Does this make sense to anyone else? ..just checking!
I used to have a Maxima too with Stillen Sway bar (rear only) it works great, but I believe that on the GS you will need both. the sway is 100% stiffer than stock, the GS suspension is not the same compare to the maxima. anyway, TRD recommend/sell them in pair only. you will be the first to try just one, get both and install just one and then the other one.
Intrax sway bars are cheaper and allow stiffness adjust. Stillen/RMM sell them. Some ppl here complain about the squeaky noise from the brushing, just oil them reqularly.
anh
anh
Registered User
Yes, yes, adjustable is what I am looking for. You may be right about needing them both, just depending on the car. Bit was cracking me because he evidently doesn't understand the concept of custom tuning.
Where in Texas are you?
I am in Houston.
I am in Houston.
TsGS4, what you are saying is accurate as far as it goes (and I suspect that you already know the following but were trying to be brief.....), but replacing front and rear bars doesn't NECESSARILY mean that you retain same balance as with previous bars. Assuming that enough choices in thickness/roll stiffness are available, balance can be altered compared to stock slip angles. But maybe I'm just picking nits.....
Me, I like oversteer anyway, as long as it's progressive and the car sends me the signals......I know it's not fastest many times, but sure is fun......
gsCrazy
11-05-07 06:46 PM
