I just got denied for the 08 Dust-Free brake pad TSIB
I just came back from stevens creek lexus service center and they just denied my request for the new brake pads. I printed out the TSIB and everything and I thought I should have no problem but they said that in order to do this your breaks have to be within a certain measurement. I looked at the TSIB and it said...
"This repair is covered under the Lexus Comprehensive Warranty. This warranty is in effect for
48 months or 50,000 miles, whichever occurs first, from the vehicle’s in-service date. "
I couldn't see anything about it having to be within a certain measurement. I'm at about 24,000 miles now. Has anyone else had this problem? and hopefully resolved??
I'm suspect the dealer meant that your brake pads are worn to the point of needing replacement and that they should be replaced anyway. Brake pad replacement due to wear is at the owner's expense.
The TSIB is about excess brake dust -- not premature wear.
If you are going to have to replace the brake pads due to wear, then you might want to replace them with the new lower dust brake pads if the somewhat lower braking performance described in the TSIB is acceptable to you.
Did the dealer tell you how many millimeters of brake pad are left? I think they recommend pad replacement at 3 mm.
It's amazing how short the life is on the new high dust, high performance brake pads on the IS. I've been used to the front pads on my LS cars lasting more than 70,000 miles and the rear pads lasting more than 110,000 miles. Sounds like Lexus has recently gone with the the type of short life, high dust brake pads that I hated on the Mercedes cars I've owned. I got real good at replacing Mercedes brake pads myself every 25,000 miles -- would have spent a fortune if I had the dealer do it.
My dealer did that to me the first time I took it in, I called them back and told them that what they said was unacceptable and that I need the tsib done asap. I took the car back the next day and they replaced them.
Ohh well.
Ohh well.
I went into the dealership complaining about the brake dust, not about pre-mature wear since I think Lexus does recommend a brake pad change around this time. I also thought lexus would give me a break since I came in in 2008 complaining about the brake dust but guess not...
It's bullfeces. I waited until my pads were toast, and then went in. They asked me several times if I wanted to change the brakes to the tsib for the low noise pads, and every time I told them that I would wait until they needed replacing, and they fully understood that and waited until 20k to change it. I could have probably got another 5k or even 10k, but the noise was bugging me.
The brake dust and squeak noise are very annoying. Got my TSIB done a few weeks back in Lexus of Pleasanton on my newly purchased CPO 350 (purchased less than a month). I guess my brake pads are still like new being only had 12k on odometer so they replaced to the low dust brake pad and no question asked.
"braking performance and feeling may be altered and could possibly be reduced under certain driving conditions".
By the way, different brake pad compositions can dramatically affect stopping distances and brake rotor life.
Tech Info Resource
READ - HPDE conditions. Not on the street and anything short of idiotic.
they can affect brake _fade_ which you won't ever see in normal street driving.
But stopping distance (ie the shortest distance the car can make a single stop from normal highway speed in) has -nothing- to do with the brake pads.
The formula to compute stopping distance doesn't even ask about your pads. It only really cares about your speed and the friction between the road and the tires (and possibly the grade of the road if not flat)
because the brakes don't stop the car, the tires do.
If you don't believe me, how about Brembo?
At the speeds that stopping distance is generally measured from (60 to 70mph), the test is primarily testing the tire's grip on the pavement. As delivered from the manufacturer, nearly all vehicles are able to engage the ABS or lock the wheels at these speeds. Therefore, an increase in braking power will do nothing to stop the vehicle in a shorter distance.
Ths part might surprise some and offend others, but it is a big misconception that changing brake pad material will magically decrease your stopping distances. In fact, you may have even seen published "data" which attempts to correlate stopping distance to friction coefficient. Although it may appear that there is a relationship between the two, there really isn't, and here's why.
http://www.scirocco.org/faq/brakes/p...n/pfpage3.html
But his conclusion is the important part-
You can take this one to the bank. Regardless of your huge rotor diameter, brake pedal ratio, magic brake pad material, or number of pistons in your calipers, your maximum deceleration is limited every time by the tire to road interface. That is the point of this whole article. Your brakes do not stop your car. Your tires stop the car. So while changes to different parts of the brake system may affect certain characteristics or traits of the system's behavior, using stickier tires is ultimately the only sure-fire method of decreasing stopping distances.
I've experienced some pretty severe brake fade on public roads that has increased stopping distances dramatically -- even to the point of having to pull over to let brakes cool down. Yep, some brake pads are much more resistant to fading and provide shorter stopping distances when hot -- you got that right.
I may be firmly in geezer territoritory and far older than most forum participants, but in my younger days I was known in my local SCCA club as "Master of the 4-wheel drift". That's OK ... no need to bow!
