IS350 brakes = ISf brakes?
I'm about to place an order for Brembo BBK and my shop told me that he ISF and IS350 uses the same specs, can somebody confirm this for me?
isf brakes are different than is350 brakes, is350 = GS brakes, is250 = ES brakes, isf brakes = isf brakes
oh wait you asked for specs... meaning what? are the isf rotors the same as the 350 rotors? is that what you mean?
Forum Administrator
Time to find a new shop if they're telling you the IS350 and IS-F (which comes with OEM Brembo brakes) are the same spec from the factory.
If they're saying you'd order the same AFTERMARKET Brembo Gran Turismo kit then it's likely they are the same unit for either car
OEM IS-F Brembo's arent a factory swap... you need an IS-F Hub to be able to swap..
I have a basically Brand New OEM Brembo IS-F BBK for sale PM me if interested!
Im just trying to get back my moneys worth... you help me & ill help you
Tech Info Resource
If it fits an IS-F, it will not fit an ISx50. The front hubs are different and the disc's hat will have the wrong spacing. If your source knows you are getting this for an ISx50, they should get the right discs in your kit.
