What to do to make power steering smoother?
Old 07-31-09, 07:58 AM
SC_Edgar
SC_Edgar's Avatar
Default What to do to make power steering smoother?
I just finished getting my power steering and rack pinion replaced on my SC300. The steering is really tough to steer and a lot of force has to be used to turn. Do I need to flush my power steering fluid and refill with ATF to get the power steering to steer smooth?
Old 07-31-09, 10:21 AM
FutureSC
FutureSC's Avatar
If the place you had your rack and pinion replaced at (assuming you did not do it yourself) used power steering fluid versus dexron II or III, that's why your power steering is horrible. Check if that's what they did because the owner's manual and the cap calls for dexron II or higher.
Old 07-31-09, 10:41 AM
SC_Edgar
SC_Edgar's Avatar
Yes, the mechanics said they used Power Steering fluid.
K I guess I will flush it out and refill with Dexron II.
Thank You sir
Old 07-31-09, 12:19 PM
FutureSC
FutureSC's Avatar
Sure, no problemo
aQuarius26
12-17-20 08:11 AM
gebo
Maintenance
10-31-19 06:45 PM
Chilo
12-01-16 08:57 AM
moneysc400
Performance & Maintenance
04-23-14 07:34 PM
jmsmiff
11-05-12 04:51 AM
Quick Reply: What to do to make power steering smoother?
