best comfortable coilovers
08-02-09, 09:58 PM
hi just wondering what brand can you recomend me for a nice coilover brand system. i want a very comforable ride because im going for 20's n my lex. thanks so much!
here are only my choices (can you guys give me a short review):
Tein SS
Tein CS
KW
Tanabe
08-02-09, 10:21 PM
Probably going to be HKS and Tein CS because of their spring rates(they're both about 7/7kg) . But between the two i would rather get HKS.
Out of that list above, i'd probably get KW.
08-02-09, 10:27 PM
08-02-09, 10:46 PM
I had the Tein CS and now i have HKS. I can personally say that the CS are not as comfortable as the HKS.
08-03-09, 12:13 AM
take Tein SS off your list if you want comfort, cant speak for the others.
08-03-09, 01:36 AM
Quote:
Originally Posted by
llamaboiz
take Tein SS off your list if you want comfort...
LMAO, really?
I got tanabes, must say the ride is perfect, IMO. it would be even better with the TEAS.
08-03-09, 09:05 AM
If you want the best damping control then go with KW's.
The spring rates might be a little bit more than the Teins or the HKS' but they will feel more supple on the road.
If you want any more info or a price feel free to PM us
08-03-09, 09:36 AM
Tein CS hands down. I have them with EDFC couldn't be happier. These coilovers ride better than stock..I can also adjust them in cabin if I want it to be stiffer or looser.
08-03-09, 10:43 AM
Tien CS + EDFC . and you should be a happy camper...
Just Dont lower it to much, as you will compromise Tien CS spring rates
08-03-09, 12:17 PM
TEIN CS for sure. It is one of the coilovers with the softer spring rates.
Good luck!
08-03-09, 12:21 PM
HKS hipermax III for sure....expensive tho
08-04-09, 10:23 PM
+1 on TEIN CS
08-05-09, 12:24 AM
i guess ill end up buying the tein cs...
im thinking of ordering a customized tein ss with 7 front and rear springs... what do you think of this? the stock spring rate of tein ss are 9 while the cs ones are 7
08-05-09, 12:34 AM
if u want comfortable ride then TEIN CS is a way to go but if u planning on going pretty low TEIN CS isn't the one.
08-05-09, 05:13 PM
BC racing with custom spring rate. They are better built and have larger internals than the CS.
