How much should dealer charge for new brakes?
Hi guys,
I am about to bring my 2006 IS350 for new break pads... hopefully I can avoid getting new rotors. I need front and rear break pads... my dealership I am sure is going to try to rape me on the price. Unfortunately I can't do it myself because I lack the time and tools necessary to do it. How much do you think would be a fair price to replace both front and rear break pads?
what about if I needed rotors... what would be a good price for rotors and pads?
Thanks guys!
Thanks guys!
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Hi guys,
Thanks guys!
Thanks guys!
i think changing the break pads should be very easy. you can find any shops and they can pretty much do the job for you and for a cheaper price. if you know a friend thats even better. for my friend's uncle, he only charge me like 10 - 20 dollars on installation and the price for buying the pads or rotors for all 4 wheels.
dealers in colorado charged 350 for fronts and 340 for rears. I think that's without changin the rotors. I couldn't afford it at the time so I got it done at just brakes for 350 total for all four.
Looking to do the exact same thing. Local dealer in Santa Clarita quoted me $600 for both front and back, includes resurfacing rotors and pads.
I called the local Toyota dealer, and was quoted $180 for the labor including turning the rotors.
I am thinking about changing the OEM pads with EBC "Red" pads. However, the EBC pads are about $200 for the front and back. While the OEM pads (front and back) are about $140 from Sewell.
Buying brake pads at the dealership is like buying tires at the dealership. It's the most expensive way to do it. I would order the pads online and install them myself since it's easier than just about anything else. If you absolutely can't do it, then find a local auto shop (not a chain) to install the pads that you provide. I would also make sure that they do NOT resurface the rotors. If the rotors are in bad enough shape to need resurfacing (they rarely are), then you should just order new rotors online. The cost of resurfacing rotors isn't just the price of cutting them, it's also a big deferrred cost in wasted brake pad material and reduced rotor life.
I haven't changed my IS brakes, but I typically just changes pads and leave the rotors as is. After 3 or 4 pad changes, I typically change the rotors (unless they wear down faster). Occassionally, I will have the rotors cut, but more times than not, I skip that part.
I was told by the dealership $425 for front brake pads and resurfacing the rotor. I went a different route and ask my boy to help me order oem brake pads and oem new rotors for both my front which came out to be only $250. Then I paid a shop $60 to install it. $310 for the whole thing which saved me well over $100. Keep in mind I got new rotor and not resurfaced one. I think they would've charged $700 for new rotors and brake pads.
thanks for all the input guys... I decided to go by the dealer to just get an idea of how much they were going to charge...
Get this...
they wanted 600 dollars to replace my front and rear break pads... with nothing else...
I laughed and I just bought my pads from I-tuned
Does anyone know how hard the DIY is? I don't want to mess it up and have squeeky breaks or have to get it towed someplace.
Get this...
I have changed many a break pad and it is easy. Granted I haven't recently kept a car long enough to change pads. When you install the pads, put some lube on the back of the pads. I forget the name exactly, just ask someone at autozone. It helps to prevent squeeky breaks. Also, make sure you have a clamp to depress the piston. Just put the clamp against the old pad and tighten slowly. The piston will push back in and then you slide the new pads in.
Get this...
Get this...
