anyone has a problem with the HID adjust lower after install F-sway?
Hi i just wonder if anyone has this problem, well I installed the F-sport sway bar myself yesterday, and tonight I was driving and saw my afs lights pointed lower than before I was adjusted. Can anyone tell me how to fix this, I installed every correctly and have no afs blinking on the dash or anything. I know when uninstalled the front sway bar I have to remove the afs link, but i installed it back to the place on the new sway, anyone know that could be that link? thanks
I don't think the sways should effect the HID aim. Did you hit the rear sensor when you put the new bar in? It is a little tight back there. Can't comment on the front as I didn't change my front sway.
If the sensors are in the proper orientation, I wouldn't mess with them. I would adjust the headlight aim. When I had the 335i, the headlights were aimed low, so I just raised them manually using the adjustments on the back of the headlight.
IS350atWOT
IS F (2008-2014)
07-27-12 07:38 AM
