How to remove upper ball joint?
Old 08-11-09, 09:39 PM
joshoowa
joshoowa's Avatar
Default How to remove upper ball joint?
Going to install my Daizen bushings this weekend and just wanted ask whats the easiest safest way to remove it without damaging them? I'm assuming pitman puller would push it up and out?
Old 08-12-09, 07:36 AM
ZippyGuy
ZippyGuy's Avatar
http://bahamutcars.free.fr/workshop/...nts/index.html
A very large gear puller might work better than a pitman puller.
Old 02-16-10, 03:50 PM
PHML
Master Thread Closer!!
PHML's Avatar
I used my pitman arm on my upper ball joint...works like a champ.
Old 02-16-10, 11:47 PM
kit cat
kit cat's Avatar
I hope you mean upper arm b/c that's an assy. but yeah, as the other said, SST puller.
have fun putting back in the upper arm, it's a PITA to get that thing aligned just right.
Old 02-17-10, 06:21 PM
Alexus_300
Alexus_300's Avatar
Easiest way is to take two dead blow hammer and tap them against the side of the ball joint. You'll see where there is two flat spot on the side of the control arm. It'll create a wedge action which will push the taper ball joint out.
Old 02-17-10, 07:59 PM
fro20
fro20's Avatar
Old 02-17-10, 08:38 PM
GS4_Fiend
GS4_Fiend's Avatar
Removing the upper ball joints you just seperate the ball joint. What do you mean by aligning the Upper Arm? All I did was just put it all back together.
Old 02-17-10, 11:43 PM
kit cat
kit cat's Avatar
I was talking about those two bolts that hold the upper arm. I always have the hardest time putting those bolts in.
Old 02-18-10, 09:18 AM
GS4_Fiend
GS4_Fiend's Avatar
oh I see. That more of disassembling. Thnks
ibidu1
09-12-17 08:41 AM
ACLC
Suspension
08-23-14 09:20 PM
Nguyen07
Suspension and Brakes
02-13-14 08:06 PM
92blacktt
05-17-09 05:32 PM
en11871
01-30-08 01:52 PM
Quick Reply: How to remove upper ball joint?
