What rubs the bag? I ride all the way down rims/tires tucked (with the 20's) until I need to make a turn, I dont recall anything rubbing please let me know cause now I'm scared.
Very nice ! glad to see they made a fix , parts look like gold to
thx, It should be a good fix....
Hey Jokster, Are you running the same set up as me? UaS & KYB? If so, lift ur vehicle on a hoist and look @ both front bags. On the outside near the steering knuckle, see if there is any wear marks or tears on the lower part of the bag. Generally, when you ride low the bags are fatter and may rub the steering knuckle. I had to rebellow both my front bags. Luckily, I found out before anything happened.
Yeah that price isn't bad at all. I like how the bags bolt on to just the top mount, eliminating having 2 parts (the top mount and the bags upper plate).
Hmm... I've had my car up on the lift quite few times these last few weeks and can but help looking at my setup cause I'm still intrigued and also just sacred that something may happen with my bad luck as usual. Anyways, I havent seen any wear at all, I'm gonna double check again thanks. and yea, I'm running kyb and uas.
So how many pieces in total? 2 or 4? Will I need the spacers too for my bags not to rub? I drive LOW, and ordered mines yesterday, but I forgot to ask.
SUPP Envy,
check out the pics on the first page... two spacers, two strut mounts..
yeah, I heard spacers, and I thought you where referring to something else. I have no clue what a spacer looks like, only heard that they relate to camber and tires. I see know that THESE spacers are just to raise the bag up.
i did a right up on these when they first came out haven't had any issues since i installed them also can drive at lower pressure much smoother ride!
yeah, a buddy of mine still has the rubbing problem. with these new mounts i know right. he has front RCA's they might have taken away the clearance. but i have no idea.
