Rear camber kit
Old 08-17-09, 09:34 AM
03SPDESIGN
03SPDESIGN's Avatar
Default Rear camber kit
Need help in finding where too buy rear camber kit? Thanks
Old 08-17-09, 10:13 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
You can get info here:
https://www.clublexus.com/forums/sus...gs98-05-a.html
Old 08-17-09, 10:30 AM
03SPDESIGN
03SPDESIGN's Avatar
Thanks for the info! But, I don't have coilovers. I have springs and struts. I did see a vendor on here that sells them. I'm waiting for them too pm me with price. Thanks again
Old 08-19-09, 03:29 PM
SorrGwa
SorrGwa's Avatar
how much camber do u have?
the SPC rear camber replacement bolts dont require coilovers.
they use a longer bolt with a larger offset circular disc, gives +1 to -1 more camber adjustment from stock
Old 08-20-09, 08:08 AM
03SPDESIGN
03SPDESIGN's Avatar
SorrGwa, I'm at -1.5 left rear and -1.8 right rear. With the SPC camber kit I should be good correct? Your input would be apprreciated. Thanks in advance.......
Old 08-20-09, 08:53 AM
GS300ToM
GS300ToM's Avatar
yes it will... basically with spc you be in spec for sure... and its way cheaper than RCAs
Old 08-20-09, 10:46 AM
03SPDESIGN
03SPDESIGN's Avatar
GS300Tom, thanks for the info.. I thought that it would be good since I'm not slamming the car. Thanks a bunch!
Old 08-20-09, 11:33 AM
GS300ToM
GS300ToM's Avatar
yeah no problem... im aboutta order rca soon for my car, tires aint cheap haha gl
Old 08-20-09, 02:43 PM
5t341th
5t341th's Avatar
iirc, for the spc camber kit, u gotta drill something.
i think its the LCA. so i guess once u put it on, it stays on
Old 08-20-09, 05:01 PM
PHML
Master Thread Closer!!
PHML's Avatar
yep...you gotta make the oem camber bolt hole larger (by drilling) to fit the spc kit on there.
once you do that...you can't undo it...spc kit stays on forever...unless you buy new lower control arms.
Old 08-20-09, 07:22 PM
03SPDESIGN
03SPDESIGN's Avatar
BS...I didn't know that! Are u guys sure about that? How much bigger of a hole from stock? What other option do I have from the SPC kit? Your input would be greatly apprreciated. Thanks
Old 08-20-09, 08:11 PM
GS300ToM
GS300ToM's Avatar
SorrGwa send that guy a PM....
Old 08-20-09, 08:12 PM
GS300ToM
GS300ToM's Avatar
have u try looking into the front spc camber uca
Old 08-21-09, 08:34 AM
SorrGwa
SorrGwa's Avatar
thats NOTHING!!!!
haha, most of us that want to retain our tires are happy to have camber less than -2 degree!
Old 08-21-09, 08:37 AM
SorrGwa
SorrGwa's Avatar
ah yes, you need to drill out the hole so its more elongated
like before its (==) now its (===) (bad example but thats as good as it gets with ascii)
the spc rear camber kit replaces ur stock camber adjusting bolt.
Quick Reply: Rear camber kit
