What springs do you recommend?
Old 08-18-09, 10:45 AM
Lexi D
Lexi D's Avatar
Default What springs do you recommend?
I'm ready to pull the trigger on dropping my 350. What is the difference between the F-Sport, Tanabe, and Eibach? Witch has the lowest drop? Thanks in advance for your help.
Old 08-18-09, 11:52 AM
projectdna
projectdna's Avatar
search is your best friend.
Old 08-18-09, 11:57 AM
ExTrEmE99
ExTrEmE99's Avatar
Out of what you listed, the lowest dropping springs is Eibach with a little over 1" all around. I believe Tanabe has the smallest drop of all the springs.
Old 08-18-09, 12:05 PM
juice14
juice14's Avatar
supposely F sport and Eibach are the same thing.
Old 08-18-09, 12:50 PM
IS-SV
IS-SV's Avatar
Has anybody confirmed that?
The drop specs for the Eibach 350 and F-Sports are exactly the same.
Old 08-18-09, 01:08 PM
silentbob
silentbob's Avatar
well...do eibach 350's clunk?
Old 08-18-09, 01:22 PM
IS-SV
IS-SV's Avatar
Good question in light of what some have experienced with F-Sports. No the Eibach 350's on my car do not clunk and no siliencers were used.
Old 08-18-09, 02:21 PM
Coconut
Coconut's Avatar
H&R springs will give you the lowest drop, at the expense of ride comfort and stock shock wear. Good chance of rubbing if using aftermarket rims.
F-Sports are rebadged Eibach 350 kit. They'll give you ~1" drop all around. By looks alone, its quite mild, but it definitely improves handling. Will have minimal impact on shock wear as opposed to stock springs.
The drop on the Eibach 250 kit would be between the F-Sport and H&R. IMO this would be the best option between looks and shock wear.
Not much experience with Tanabe and Tein springs since the drop looks noticeably uneven.
Old 08-18-09, 04:11 PM
hmsis250
hmsis250's Avatar
I had Eibachs, then switched to coils. I got use to the look and wanted to go lower. Coils is the best way to go because you can adjust the ride height. The funny thing is now, I want to go lower, so thinking of going air!
Old 08-18-09, 04:47 PM
intekmdma
intekmdma's Avatar
You might want to think about looking into getting some coilovers instead. I purchased springs / shocks for my previous car and loved it. But then I got used to it and wanted it lower. Adjustability of height is something worth looking at.
Old 08-18-09, 07:32 PM
Lexasaurus
Lexasaurus's Avatar
I just got some Tein S-Tech's today, should have them next week
Old 08-18-09, 07:38 PM
llamaboiz
llamaboiz's Avatar
i had eibach 350 springs, switched to tein SS coils... imo do not get eibach 350 spring/Fsport (same drop) but get eibach 250 springs even if you have a 350, much better drop.
Old 08-18-09, 08:47 PM
funnie
funnie's Avatar
I have the f-sport springs and am ready to put those on my 350. After more research and speaking to friends that been in the car modding world longer they highly recommend coilovers. Man those things are expensive! I am torn now if I should just go ahead n put on the springs or go with coilovers. I do like that coilovers allows u to set the stiffness / height of the car. Just something to think about. GL
Old 08-19-09, 10:00 AM
hkmember23
hkmember23's Avatar
I have always enjoyed Eibach Prokit springs
Old 08-19-09, 11:19 AM
dojoman
dojoman's Avatar
Whenever you talk to people, especially those in modding scene they WILL always recommend coilover. If you're like me, just want subtle drop, coilover are overkill.
Yes it's cool that you can adjust the height, but are you sure you want to do that every weekend? It's not like you push a button and it drops, you need to lift your car take out the wheels.
I'm not bashing coilover but just not for people that want subtle look.
Quick Reply: What springs do you recommend?
