Loud and Constant Sound when I brake
Old 08-18-09, 07:53 PM
Sheehan1p
★ I
Sheehan1p's Avatar
Default Loud and Constant Sound when I brake
Hey guys we recently changed the front pads because the older ones were worn out. When I went to Midas they also suggested that I get new rotors but we did not do that. Now when I am braking say from 25 or 35 mph to a stoplight or whatever I here this constant loud sound (really dont know how to describe it) from the front, could this be from not changing my rotors? Is this normal and does this hapen to you when you brake?
Thanks!
Old 08-19-09, 05:06 AM
Mike813
Mike813's Avatar
did the mech grease up the fit kit & shims? without the grease it causes a loud squeak under load...
Old 08-19-09, 06:31 AM
Debonair
iModerate
Debonair's Avatar
Loud grind, squeak, thud, bang, chirp, whine?????? Loud sound is not enough info.
Old 08-19-09, 07:57 AM
Sheehan1p
★ I
Sheehan1p's Avatar
It is really hard to descrice it doesnt happen when I am not applying the brakes, but when i do it seems like it coming from the wheel well area and it sounds almost like the wheels are grinding on something.
Old 08-19-09, 08:47 AM
Debonair
iModerate
Debonair's Avatar
Take it back and have them check it out. Brakes are not something to ignore.
I have had this issue in the past with brake pads "glazing" from being overheated. Do you drive and break pretty hard?
Old 08-19-09, 08:53 AM
GS300ToM
GS300ToM's Avatar
take it back!!!!!!!!!!! and its always recommended to resurface your rotor on new brake pads if possible
Old 08-19-09, 09:38 AM
Sheehan1p
★ I
Sheehan1p's Avatar
no i dont drive that hard at all, it happen when i even stop from say 20 or even 15 mph
Old 08-19-09, 12:12 PM
kit cat
kit cat's Avatar
unless you knew someone that works there, I wouldn't even take my beater there lol.
Old 08-19-09, 02:07 PM
Debonair
iModerate
Debonair's Avatar
This is true for any shop including dealers. If you are not going in knowing the shop/employees or based off a trusted recommendation it will always be a pretty big gamble.
Old 08-19-09, 02:28 PM
GS300ToM
GS300ToM's Avatar
i dont trust anyones work unless i've seen it myself by yeah its a gamble all rite
Offspring
10-24-18 12:43 PM
Epic123
Suspension and Brakes
13
10-30-11 04:30 PM
alanbkahn@
05-01-07 12:37 PM
Kharizma
04-15-06 05:52 PM
jtanoyo1
07-30-03 04:06 AM
Quick Reply: Loud and Constant Sound when I brake
