L-Tuned Steering ECU Install Help Needed.
A few people have pointed out that the l- tuned steering ecu can be installed without taking the panel off. I guess all you need is #10 socket with extension. Can anyone with experience, let me know exactly where the location is under the steering panel. Here are a few pics. Thanks!
Can someone detail this location on the picture I have included? I have searched every post and the DIY does not explain it:
http://members.rogers.com/lexusrules/ltuneecu.html
Thanks.
Thanks.
Thanks.
Thanks.
bad-gs400,
I just installed the ECU a couple nights ago. I only removed the bottom panel like you becuse I couldn't figure out how to take apart the other panel. The instructions #5 on the ltuneecu.htm don't really tell you where the location of the one screw is. Anyways, I messed with the pics you sent and tried to give you a ball park as to where the ecu is. I brought the socket wrench from underneath where the bottom panel was, but I was looking thru the hole under the parking brake release handle.
good luck...
jonathan
good luck...
jonathan
jawnthen- Thanks for the detail in the picture. I tried taking off the panel right above the gas/brake pedal, which had 2 bolts and a clip. The only issue is the center is basically attached by something. Does this just pop out or is there a hidden bolt? It looks like if this comes off, it will be easy to get at the ECU. Any thoughts? Thanks.
bad-gs400
Suspension and Brakes
47
06-27-02 01:55 PM
