F-Sport suspension and ridiculous camber and tire wear
Old 08-27-09, 11:13 AM
FisforFast
F is for Fraud
FisforFast's Avatar
If you have a problem with your car, bring it back to the dealer and have them fix it. Don't come on here groaning and moaning for help and then discrediting everything everyone is saying. Higher wear and tear from performance accessories is to be expected - you shouldn't need a disclaimer, and if you're so in-tune with performance modifications, you should've known this from the get-go.
For the record, my car is being serviced by Robin Almasi himself from Almasi Tuning, who revolutionized Japanese automative tuning here in Canada and in the northern U.S. He is probably in a much better place to comment about this problem than your SoCal Porsche and Audi guys. I will be giving him a call to see what he thinks, but I'm guessing he'll be telling me that you should just go to the dealer and have them deal with it, as F-Sport accessories are backed by a warranty if installed by an authorized dealer.
Old 08-27-09, 11:39 AM
IS-SV
IS-SV's Avatar
Originally Posted by nicholasg
Toe has NOTHING to do with camber. That was a totally ignorant statement.
Toe is adjustable and will reduce this kind of wear. Do a search and you will find those with much more expertise on this topic that can explain it very well.
Old 08-27-09, 11:52 AM
Coconut
Coconut's Avatar
I still think the main culprit of your "premature" tire wear is too much toe. Theirs a TON of info on this site regarding inner tire wear and toe, just search. -1.5 camber is out of spec but I don't think its enough to have a major impact on tire wear.
Old 08-27-09, 12:02 PM
Thr3350
Thr3350's Avatar
I doubt you get your cars serviced by such a reputable place.....
Old 08-27-09, 12:26 PM
Kurtz
Kurtz's Avatar
Ok, I am getting frustrated. Im not sure how many cars you people have owned
Way more than you.
, or your prior experience with modifying vehicles.
Way more than you.
No, but toe has a lot to do with alignment. And inner tire wear on the 2IS. Which was, ya know, your problem.
if you disagree, call your local performance suspension shop and ask them. I personally had GMG check my suspension. I doubt you get your cars serviced by such a reputable place.....
Since you have such 'experts' on the job, why are you asking here?
Old 08-27-09, 12:29 PM
Buds
Buds's Avatar
I'm going to repost this snippet that Lobuxracer submitted on a different thread with a similar issue:
I can't believe all the BS in this thread. NORMAL? HELL NO!!! There are only two things that wear out the outer tread blocks - too much toe in (does NOT meet stock spec) or consistently very hard cornering.
Inner edge wear should NOT happen again unless there is too much toe out - there is NO other reason. There isn't enough camber in this car to wear anything prematurely and camber isn't the issue at anything less than -2.5 degrees. The front is -0.8 and the rear is -1.5 - pretty normal for a factory alignment to ensure the car understeers.
I went 32k miles on my factory Bridgestone RE050s. Iv'e gone nearly 30k on my RE050A PPs and they're about half worn. Proper alignment does amazing things.
The biggest problem with alignments is the guys doing them are usually minimum wage idiots. They don't understand the principles behind what alignment does, they just set up the car to show "good" on their computer controlled devices. It rarely results in good alignment for the performance driver, and frequently doesn't even meet the needs of the casual driver. There's a lot to be said for having someone who really knows what he's doing working on your car's alignment. Even if it is only toe adjustment.
For instance - how many alignment techs actually check air pressure before they do the alignment? Having the correct pressure in all four corners is critical to getting the alignment right. How many actually measure ride height? If the ride height isn't correct, NOTHING will be right according to the factory specs.
So, wearing out the outside or inside edges of your tires is NOT normal for any 2IS - it is a clear sign there is an issue with your alignment or possibly your driving.
__________________
Old 08-27-09, 02:06 PM
mikez
mikez's Avatar
All I needed to say here has been said lol
Old 08-27-09, 02:07 PM
IS-SV
IS-SV's Avatar
lol, That's one opinion. But the OP's questions were addressed for sure.
Old 08-27-09, 05:24 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,002 Likes on 2,424 Posts
Just an FYI - my Supra runs -1.5 degrees on all four corners. I have no issues with inside (or outside) edge wear. When the alignment was at exactly the stock settings (3mm toe in at the rear) I burned through a set of D40M2s in 6k miles. I reduced the toe in to minimum spec - 1mm - and I never had another inside edge wear problem even with -1.5 degrees of camber. If you Google "lance alignment" you'll see what I came up with to fix the Supra's stock alignment.
So, if you go to arbitration with Lexus, you'll be shot down like a fool. They'll hire someone like me to show up with facts, figures, and geometric drawings and you'll lose. Guaranteed. Because camber doesn't wear out tires unless it exceeds -2.5 degrees. Toe will kill a tire at 0 degrees because toe is the biggest factor in tire wear for street drivers.
Old 08-28-09, 03:25 AM
MrHarris
MrHarris's Avatar
My camber is -1.7...
Old 08-28-09, 07:14 AM
smokyis350
smokyis350's Avatar
Lobux: I live in Northern California and can't find a professional shop that actually measure the ride height and check the PSI. What is the recommended tire pressure for the alignment? I have aftermarket wheels. Also, is there any specific specs that I should tell about? I have the same issue as the OP and everyone else on the forum..
Old 12-20-09, 04:23 PM
AZ06IS350
AZ06IS350's Avatar
Default Back from the Dead
I'm having the same issues as the OP and others on this forum. Many have chimed in on alignment, yet I did not read one person give the recommended toe adjustment for front or rears that will eliminate (or at least slow down) the uneven treadwear on the inner block. The same goes for the camber, many people responding but no clear suggested measurement. I read a few saying their camber was -1.5. I know that the camber spec range is +.2 through -1.4 for the front and -.5 through -2.0 for the rear. I am riding on Tanabe NF210s which lower the front .8" and the rear 1". I get an alignment every 6 months and whenever I replace tires (which is more often than I should be).
I would appreciate feedback from those who know their toe/camber specs on their vehicle that is getting even tire treadwear.
Old 12-20-09, 05:14 PM
quang
quang's Avatar
bring to the dealer.
Old 12-25-09, 02:26 PM
2slow
2slow's Avatar
Camber was -1.9 but fixed and went down a bit...
But toe plays a big part is tire wear as well.
Old 12-25-09, 03:38 PM
GiantsFan
GiantsFan's Avatar
A GOOD alignment shop should be able to fix this...
Quick Reply: F-Sport suspension and ridiculous camber and tire wear
