Spacer size to clear BBK on OEM 16" wheels?
09-01-09, 07:37 PM
so I've recently been getting extreme wheel vibrations when under hard breaking and was thinking of upgrading my break system. I dont want to invest in a new set of rims right now so i was wondering what size spacer I would need to clear the bbk? specs for supra TT or LS would be great.
Thanks
09-01-09, 09:29 PM
Maybe warped rotors are causing the vibrations. I'm not sure a spacer would even help in clearing bbk under 16s.
If anything, you can try this to get an estimate:
http://www.stoptech.com/tech_info/wheel_fitment.shtml
09-01-09, 10:34 PM
15mm should work for the stock 5 spoke 16's to clear the LS caliper. I'm not sure if 16's would clear the Supra TT.
09-02-09, 08:55 AM
16's wont clear the supra TT bbk with spacers
09-02-09, 07:52 PM
17 inch rim minimum for both ls and supra brakes.
09-02-09, 07:57 PM
Quote:
Originally Posted by
One HoT
What he said! I am doing the same set up on my gs.
09-02-09, 08:07 PM
Im doing the LS setup as well...Is there really a significant difference between the two setups? Also what do you guys do for the rears?
09-02-09, 09:09 PM
One HoT
16's with a 15mm spacer will work with the LS brakes.
09-03-09, 01:45 AM
Blkexcoupe
hummm I have the 7 spoke 16's, do you think they are the same for clearance?
09-03-09, 03:38 AM
SC30096
I have no idea if the 7 spokes have the same clearance.
09-04-09, 12:31 PM
does anyone have LS400 BBK on 7 spokes??
09-04-09, 03:52 PM
A lot of pedal play on the new rear Supra TT BBK
09-05-09, 12:36 AM
hmm..i have a ls400 set up in my garage...maybe i should do this
09-05-09, 08:05 PM
interesting. I wonder if the supra brakes have the same clearance. I have the supra donut and it is a 17 inch donut.
edited. 16in will probably not work for the supra brake since the rotor diameter is slightly larger.
09-06-09, 06:56 PM
One HoT
I don't think 16's can clear the supra brakes. Generally spare tires are the minimum size to clear the brakes, so it comes with a 17" spare for a reason.
will33184
Wheels, Tires & Brakes Forum
19
09-27-06 12:55 AM
LEXUSGS430
Suspension and Brakes
08-31-06 09:20 AM
Wald GS
02-23-05 09:42 PM
bbk ,
caliper ,
capsule ,
clear ,
donut ,
hot ,
i6 ,
lexus ,
ls ,
rim ,
spacers ,
spare ,
star ,
tires ,
yellow
