Part number for OEM front rotors (250 awd)
I've been searching but wanted to quadruple check that I got the right part number before putting in an order for front rotors. For some reason, my front rotors are worn out like crazy. It has a fat lip at the edge that if I resurfaced them I might as well buy new rotors. The stealership told me $477 for the front rotors and install.
The part number I found is: 43512-30310. Is this correct?
Save yourself alot of money and go with Centric (Stoptech) Premium Rotors. They only cost about $60 each. The part number for the front rotors for an IS250 is:
120.44125 (L and R rotor are the same)
Oh, will the Centric rotors do fine with oem brake pads? The stealership did give me a free set of pads.... i guess their way to convince me to fork up $477 for the front rotor job. haha
Check out the "Vendor Marketplace" section on this forum. I usually order from NigelJDM and Jay@Static. It doesn't hurt to get a few quotes from other vendors here as well...
https://www.clublexus.com/forums/clu...rketplace-118/
The Centric rotors will work fine with your OEM brakepads. They either meet or exceed OEM spec. The OEM rotors might even be Centric parts...
If you need OEM parts like brakepads, filters, etc. check out Sewell Lexus parts online. Use coupon code "clublexus" at checkout to receive 10% off. They are MUCH cheaper than dealership prices.
rclab1
04-03-07 10:54 AM
