Nervous as hell... (installing F sport springs tomorrow)
#31
I really want H&Rs... it's the best drop IMO on springs, and is linear compared to the F-Sport's progressive springs (resulting in the clunking noise) but I already scrape on some ares on STOCK suspension ...so even though I don't want to, I may go for f-sports... but im still thinking...
can't wait for some pics!! It may help me decide lol![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
people think about lowering their car to much its just freaking springs "just do it" you won't regret it
#33
Any update? I personally will like to know if the ride height are equal on all corners. I heard this is a huge problem with Lexus...you will notice one side is higher than the other after installing lowering springs.
#34
but projectdna, the installer guy claims to have the magic touch when installing springs. that is the reason why no alignment needed. i guess u dont believe in such thing.
I always thought alignment is required after any spring installed. its better to be safe than sorry.
with all due respect to Fizzboy7's installer, he can be a certified lexus master technician, or he can be some random john doe working out of a makeshift garage and making claims of this or that, i don't care. the "the magic touch" doesn't mean anything. if i'm getting major work/removal/replacement of major suspension components, i know i'm going to require an alignment.
on the other hand, if he is that damn good that he can eyeball the post-install alignment and get it within half a hair of the oem alignment specs, i'm not going to rest on his word. again, no disrespect, but numbers don't lie.
i'm not being skeptical; i'm being realistic. prove it to me, and i'll stand corrected.
thank you.
btw, i thought he was in norcal, so with that regard i stand corrected. but if he wants a quality installer in socal who's worked on quite a few 2is's, i can recommend someone to him...
#35
#36
"magic touch" doesn't apply to auto mechanics. if that was the case, i'd like someone with a "magic touch" to make my 2is handle like a go-cart, but i digress...
thank you.
btw, i thought he was in norcal, so with that regard i stand corrected. but if he wants a quality installer in socal who's worked on quite a few 2is's, i can recommend someone to him...![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
thank you.
#38
I'm in SoCal. Leaving in 30 minutes. Will post my thoughts tonight if I am not going out late to celebrate (this is big!).
As Glenn Frey once said, "The Heat is On!" (before you're times)
#42
When I had my Fsports installed, I went in for in an alignment the next day and my car was in spec, including toe, which is critical to tire wear. Camber was around 1.6-8 ish in the rear. Waited a month later after the springs settled and returned to the same shop, and the car was slightly out of spec. (toe) and got it aligned.
I think the Fsports are mild enough and may not need an alignment directly after the install, but may need one after they settle. I always wait for the springs to settle and do another alignment after a drop on any of the cars I've owned.
When I first dropped the car, the look was very modest. Now after 6 months, the car has lowered even more and looks much better. The Fsports are great if you want something mild. Slamming my car wasn't an option if I have to have clients in the car with me.
#43
