DIY power steering hose replacement
Old 09-03-09, 08:46 PM
tritron
tritron's Avatar
Default DIY power steering hose replacement
So many people have high pressure power steering hose leek leek. Good opotion seems to get driftmotion hose for 65. Now we will loose idle up valve and pressure switch. The power steering pressure switch is attached by two wire plug so shorting them increases rpm and flow of fluid making very easy to turn.
Now i wonder if is possible to buy plug that will plug in inside switch harness and then run wire and switch seems that under steering there is good place for switch.
Old 09-04-09, 05:35 AM
SCoupe
SCoupe's Avatar
https://www.clublexus.com/forums/sus...n-for-scs.html
I'd sure want to know more about who and how members have used the driftmotion hose because it certainly does not come with the required banjo fittings. There are no AN or NTP style fittings on oem hose. The driftmotion hose in no way resembles the SC300 high pressure hose and would have been of no help.
Old 09-04-09, 06:20 AM
tritron
tritron's Avatar
The whole idea of this post is to create pressure switch
Bypass . It makes steering normal.
mirekti
03-11-18 08:54 AM
bucfan22
ES - 5th Gen (2007-2012)
07-29-17 03:08 PM
Allaretake
Performance & Maintenance
05-03-12 01:19 PM
tritron
Suspension and Brakes
08-21-09 08:00 AM
Rick 634
05-03-07 03:28 PM
Quick Reply: DIY power steering hose replacement
