What's the most ideal way to lower your car without coilovers?
Take out the damper/spring combo.
You'll be sitting so dumped broseph, it'll be so frickkkkkkin rad.
ahahahah. damper/spring combo is obvioulsy the ideal choice if you want to go lower w/ out coilovers.
That or bags.
by the way, you can't ever get an even spring rate all around or two and two if you cut because the cuts will never be exactly the same. They may be slightly off if you do your h.w. but it'll never, truely be even.
Goodluck, OP.
That or bags.
Goodluck, OP.
Are these the megan coilovers someone mentioned previously?
Or are they these? These are probably it. I saw the other one first.
to everyone else: The good sides to the megans are that they are cheep and you can adjust the height. The bad sides are they feel pretty crappy compaired to other shocks.
If you go with the shock and spring combo, you end up with that height if you like it or not. Thats where cheepy coil overs like megan help, if your more worried about getting the right height, get cheepy coil overs. If you more worried about how your car rides and handles, get springs and shocks. If you have the money to get both, your reading the wrong post and probably should be on the supra forums.
^^ cheap coil overs like megans will blow on you, especially if you drive on **** roads like here in canada.
I went with the bilstien/hypercoil setup and everyone else over here bought the megan or tien setup for their soarers.
One year later, I am the only one without blown shocks
. (I am the only one who dailys their car as well)
philliptie
Suspension and Brakes
02-08-10 02:54 PM
