Getting F-Sport Suspension Installed Tomorrow!
yes still clunking but seems not as loud, maybe I got used to the noise? I already talked to them, they said it's normal springs noise. I should've install the silencer before installing but not sure they will put them on for free afterward.
The more I read (on CL forum) about "resetting bushing procedure" and the written instructions that came with my Eibach springs, I wonder if all the shops are really following these procedures that closely.
Is the noise just from rear suspension area? And on what kind of bumps?
Given the number of folks who are under the mistaken impression that steel springs "settle" I suspect relatively few shops actually do it correctly.
My opinion, if you buy the Tien siliencers, then they should install them for you, so that you are a happy customer.
Maybe you should stop by one day to hear it in person. PM me if you're interested.
I hear from rear suspension only especially the passenger side. I don't hear from driver's side maybe because I'm driving? I only hear this "thump" only when I drive on a really high speed bumps with high speed. If I slowed down significantly I don't hear it at all.
I'm curious, do you hear it going over speedbumps in parking lots?
I have the exact same problem & location as you described on my 2009. I brought it back to the dealer where I road tested it with their technician. He agreed that the 'clunk' noise was isolated primarily from one side and was not normal 'lowered suspension noise' as he first suspected. He kept my car overnight so they could remove the springs and inspect.
The next day my service rep called me and told me that these F-sports are defective, and manufacturer realizes this so they are producing a replacement. He said that the new version of the F-sports will be released to the dealers within a month and that he would swap them out for me under my warranty.
I have the clunking in the right rear on speed bumps with my F-sports too. The faster i go through the speed bump, the harder it clunks...
I made a thread about this a few weeks ago:
https://www.clublexus.com/forums/sus...ight-rear.html
FYI...
I was really anxious about the clunk noise, so after installation I hit every bump possible-- sped over speedbumps to try to create the noise, but nothing I did could make anything that sounded like a clunk! I will keep you guys updated.
As you can see from my pics, I only have a silencer on the 2nd and 4th dead coil of each rear.
I think the silencers can be installed without any disassembly. So maybe they can just put it on the lift and install Tien silencers.
