a stup!d girl question... (suspension squeaks)
Old 09-14-09, 03:30 AM
Annalyz
Annalyz's Avatar
Default a stup!d girl question... (suspension squeaks)
my f-sport sway bars are squeeky! is it because i didn't grease the bushings? i glanced over the instructions and didn't see anything about greasing them...
i did a search on noisey f-sport sway bars and found a thread in the gs section... does the is have the same issues?
thanks in advance, lei.
Old 09-14-09, 04:33 AM
ndk83
ndk83's Avatar
do u have F-sport springs?
How cant u tell tis the sways that are squeeking?
Old 09-14-09, 04:50 AM
vdubturbo
vdubturbo's Avatar
Valid point... although in my experience suspension squeaks are almost always bushings. I've never installed f-sport sways, but every other bar I've installed came with lube.
I did get lazy on a set of poly control arm bushings once that squeaked... but it eventually went away after 2 weeks.
Old 09-14-09, 08:17 AM
ULTiMaX99
ULTiMaX99's Avatar
i thought i read somewhere that the f-sport bushings don't require greasing? maybe something else is squeaking?
Old 09-14-09, 10:42 AM
Annalyz
Annalyz's Avatar
i'm running tein cs coilovers...
the squeeking started after i installed the sway bars... can someone tell me if the bushings are polyurethane? if so, i should grease the bushings... right?
err, i'm just a girl...
*i hear the rubber rubbing squeeky sound when i turn and go over bumps...
Old 09-14-09, 10:45 AM
JeffTsai
JeffTsai's Avatar
Depends if the bushings are hard rubber or polyurethane. On the GS's the poly bushings require lube and the rubber ones don't. Generally Toyota products use rubber bushings...yes that includes TRD and Fsport
But you should still double check to see if they're rubber or poly just to be sure. The poly bushings have a shiny look on the surface, kinda like plastic. Rubber bushings have a dull look.
Old 09-14-09, 10:58 AM
PHML
Master Thread Closer!!
PHML's Avatar
Lei, did u torque the bolts back to spec? If no lube...and over-torqued...that may cause it to squeak.
Old 09-14-09, 11:16 AM
Annalyz
Annalyz's Avatar
they looked sorta kinda shiny... err, i don't know? if they're rubber bushings... will the grease hurt?
Old 09-14-09, 11:39 AM
Annalyz
Annalyz's Avatar
torque? uhh, heh... opps!
i know, i didn't over tighten... i had a hella hard time taking off the stock sway bars bolts!
imma take off the sway bars off, grease the bushings and torque them back on... shucks, i can't handle the squeeking! can someone tell me how many pounds to torque the sway bar bolts?
lei.
Old 09-14-09, 12:21 PM
GiantsFan
GiantsFan's Avatar
I believe you are NOT supposed to lube F-Sport sway bars!!!
Old 09-14-09, 12:26 PM
Annalyz
Annalyz's Avatar
i'm talking about the f-sport sway bar bushings...
Old 09-14-09, 03:19 PM
triple_c
triple_c's Avatar
The F-sport replacement bushings are supposed to be self-lubricating, so no greasing is supposedly required. But what the hell, if they squeak, grease them up
Old 09-14-09, 03:27 PM
masagsxr
masagsxr's Avatar
All sway bar bushings in the past that I've replaced I've always greased them up. Shouldn't be that hard to do. Couple of bolts to take off on each side, apply the grease and put them back on...
Old 09-14-09, 04:02 PM
eric_r_ho
eric_r_ho's Avatar
Torque spec is probably aroud 27-30ft/lbs..
Old 09-14-09, 07:37 PM
GiantsFan
GiantsFan's Avatar
Yes, thats what i meant as well. From what I have read, these do not need to be lubricated.
Quick Reply: a stup!d girl question... (suspension squeaks)
