Can't Remove Caliper Need Advice
Old 09-18-09, 09:01 PM
Champstar
Champstar's Avatar
Default Can't Remove Caliper Need Advice
Finally doing the LS400 caliper upgrade and before I can even star the fun part my caliper bolts wont budge
I've tried my homeade torque bar
Then I pulled out my torque wrench (250lbs max) and it still wouldn't budge
tried for over an hour then gave up
What should I try next?
Any advise will be helpful
Old 09-18-09, 09:16 PM
Mr Jokster
Mr Jokster's Avatar
You turning the right way? (hey it happens) I was having the same problem yesterday, I took a 25lb sledge to the ratchet; just dont do what I did and take your thumb with it I crushed my thumb... anyways, yea. Also use some liquid wrench and/or WD40.
Old 09-18-09, 10:06 PM
kit cat
kit cat's Avatar
heat it up, then PB blast it?
Old 09-19-09, 02:50 AM
5t341th
5t341th's Avatar
dont use your torque wrench to open nuts/bolts. it screws it up.
like they said, use pb blaster/liquid wrench/a torch
Old 09-19-09, 03:31 AM
samst205
samst205's Avatar
go get a real long pipe
Old 09-19-09, 02:21 PM
SoloKaMGS
SoloKaMGS's Avatar
champstar sorry if im bothering ur thread. are you doing the LS400 rear caliper upgrade. what exactly is needed to do the upgrade. Thanks so much for the help.
Old 09-19-09, 04:07 PM
Champstar
Champstar's Avatar
nope just the fronts
finally got it loose with some PB blaster a wrench and a sledge hammer
Old 09-19-09, 10:00 PM
SoloKaMGS
SoloKaMGS's Avatar
great job on that. i am trying to do the ls400 rear caliper and wondering the parts i would need to get it done beside the caliper on my 98 GS300.
Old 09-20-09, 12:05 PM
vwynn
vwynn's Avatar
i use my air tools
1999sc300
05-05-17 01:27 PM
endlesslex
06-10-14 01:30 PM
Kayasith95
Suspension and Brakes
01-13-13 06:32 PM
Durrby
01-02-11 03:14 PM
teoh2005
IS F (2008-2014)
05-03-10 09:46 AM
Quick Reply: Can't Remove Caliper Need Advice
