question about springs.
i know their several springs out there,
just wondering which ones give you the lowest drop?
i have springs right now but have no idea what they are, the guy i bought it from told me they were GS springs, have no idea what he meant by that..
cut the springs .... j/k... if Intrax is available, i think they give the lowest drop.
Some brands.... trd, intrax, h&r, suspension techniques, sprint, eibach, tein, skunk2 or skunk works, ground control... i'm sure there are a lot others i'm missing.... Good luck.
http://www.roadmagnet.com/Lexus-IS-250
in comparison:
H&R springs for the 2is will lower ride height by 1.4" up front, 1.3" in the rear.
http://hrsprings.com/scripts/appguid...ind3&MakeID=20
tein s-tech springs for the is350 will lower ride height by 1.6" up front, 1.2" in the rear. for the is250, it's 1.7" up front, 1" in the rear.
http://www.tein.com/products/s_tech_price_list.html
eibach pro-kit springs for the is350 will lower ride height by 1" in the front, 0.8" in the rear. for the is250, it's 1.4" up front, 1" in the rear.
http://eibach.com/cgi-bin/htmlos.exe...07745500027676
tanabe nf210 springs for the is350 will lower ride height by 0.8" up front, 1.0" in the rear. for the is250, it's 0.7" all around.
http://www.tanabe-usa.com/nf210.asp?id=2
tanabe df210 springs for the is250 will lower ride height by 1.0" up front, 1.1" in the rear. no application information for the is350.
http://www.tanabe-usa.com/df210.asp?id=1
megan racing springs for the 2is will lower ride height by 1.25" all around.
http://www.meganracing.com/products/...=643&catid=141
f-sport springs for the 2is sedan (not the IS-C) will lower ride height by 25mm up front, 19mm in the rear (~1"/0.75").
http://www.fsport.com/
i think that's a comprehensive list of manufacturer specs for aftermarket lowering springs.
^ that is true, and a search through the 2is suspension section didn't yield much information for "road magnet" and "rwd" either.
i'm not an expert in automotive suspension systems, and there is a pretty good possibility that this is wrong and illogical, but for argument's sake:
awd 2is ride height w/ road magnet springs = rwd 2is ride height w/ tein s-tech springs...
and since awd 2is oem ride height = rwd 2is ride height + ~1" (more or less?)...
therefore, rwd 2is ride height w/ tein s-tech springs = rwd 2is ride height w/ road magnet springs + ~1" (more or less).
so according to the ^ logic, road magnet springs have a lowered ride height moreso than other aftermarket lowering springs.
again, there is a pretty good possibility that this is wrong and illogical...
Tech Info Resource
