I think the calipers are under $200 on the classifieds. The Supra TT calipers cost much more and the TT rotors are only like 3mm bigger. LS400 brakes are really good for the money, and they're lighter since they're all aluminum.
People say drilled and slotted rotors tend to crack but I've used them before with no problems. I don't track my car or anything.
Brakes look dope chrispy!.. How much did you get those calipers for if you dont mind me asking? Im torn between supra and these.. Im gonna get the front RCA so I can fit either.
Wow, that sucks that the rotor cracked.. Is that because its slotted and drilled? is that a certain brand that cracks like that?
No vibration here after i did mine. What brake pads are you using Chris?
I think they are OEM. I'm not sure since they are used. I figured out the vibrating was only happening when stopping from high speeds around the 60mph range. Turns out to be a bent wheel.
I'm not sure how light the LS calipers are compared to the Supra TT but they are about the same or lighter than the stock calipers. Very light for their size.
