front suspension fixes and facts
Old 03-22-11, 06:23 PM
  #181
RoboRam12
RoboRam12's Avatar
Originally Posted by pizdets17
my steering rack was adjusted and is perfect. My car shakes with 16's and 18's and 20's so what you're saying about denial is irrelevant.
Is the actual rack secured properly to the vehicle, all the bolts tight and junk.
Old 03-22-11, 11:08 PM
  #182
pizdets17
pizdets17's Avatar
They did it with the weird hex adapter thing so yes lug centric.
Originally Posted by Och
Are you 100% sure they did lug centric balance? Are you using proper lugs?
I've suffered from the shakes in the past and they were all related to wheels only. With properly balanced wheels I was driving with no shakes even when my caster arms bushings were shot to the point where they were being held together by a miracle and my upper ball joints had tons of play.
Old 03-22-11, 11:09 PM
  #183
pizdets17
pizdets17's Avatar
yes its like brand new under there, car has 60k on it and all the steering rack bushing have been changed to Daizen as well.
Old 03-23-11, 09:46 AM
  #184
skperformance
skperformance's Avatar
Glad this thread is going strong with some good info .
One thing I have learned is that when ever you take a firm stand on something you will always have someone correct you whether true or not.
Alright , so we have some saying it is balancing of the wheels causing or having nothing to do with vibrations.
You can roadforce your wheels all day and it will still vibrate with the worn bushings .
Q. Why is that , how could that be ? It is the best possible balancer that will fix imbalances , right ?!
A. Here is why it can't fix the vibrations with just a balance .
When you have you wheels balanced it is only balanced on one axis , do they take into account your toe or camber degrees when they balanced it ?
Nope , they did not !
So what this means , is that in the real world when you get them balanced , once the wheels get on the car and driven the angles are changed it will not be in spec anymore to the balancer . How bad out of spec is dependent on the bushings in this case .
Remember the worn caster bushing changes the front wheels to positive toe and negative caster . If it didn't unbalance the wheel it would not be wearing the inside of the tires so heavily from scubbing .
Not every wheel is the same and has different balancing properties . This is especially apparent when cars are lowered from negative camber but toe will show its ugly head very strongly when an imbalance problem shows.
One thing i have seen when i was at technician college was a hunter balancer that was dynamic . Meaning it was applied to the cars wheels while still on the car . It would then balance the brakes the hubs and drive shafts. Truthfully that is the best possible balancer money can buy if they still make it anymore as that was a long time ago.
Old 03-23-11, 09:52 AM
  #185
RoboRam12
RoboRam12's Avatar
They still do, we're training on one of those Hunter racks at school.
And you are right about the bushings, you can align your car 10 times, but it doesn't matter if you have bad bushings. That's the problem I found my car has, just haven't gotten around to replacing them because I don't have any money right now.
Old 03-23-11, 03:23 PM
  #186
Och
Och's Avatar
But the bottom line, the shaking must start somewhere and it starts at the wheels.
If the shaking is only present at certain speeds (usually ~60mph) it is most certainly the wheels.
If its at all speeds, it could be that the wheels are off center, bent, or could be that something else is very looses.
Bad bushings and other suspensions components that are loose will of course multiply the shaking and by the time it gets to the steering wheel, it will feel a lot worse.
I was fighting shakes for a long time in the past, and it turned out to be the wheels. On the other hand, I was driving with no shakes at all when both my UCA and caster bushings were completely shot.
Old 03-23-11, 06:26 PM
  #187
RoboRam12
RoboRam12's Avatar
Check out your wheel bearings to see if any are loose. Do this by jacking your wheels off the ground and seeing if it has any movement when you push or pull it. You won't get the normal sounds of a bad wheel bearing, but it can also cause the vibrations you're describing.
Old 03-23-11, 06:35 PM
  #188
pizdets17
pizdets17's Avatar
bearings are perfect. Must be the 3 sets of brand new rims eh?
Old 03-24-11, 04:46 AM
  #189
RoboRam12
RoboRam12's Avatar
Just because they are brand new doesn't mean they are good wheels.
Old 03-24-11, 09:10 AM
  #190
pizdets17
pizdets17's Avatar
Dude, TOYOTA FACTORY RIMS. Times 3.
Old 03-24-11, 09:12 AM
  #191
Och
Och's Avatar
Pizdets, I looked at some of your old posts, and you were saying before that you never had shakes with 16's?
Old 03-24-11, 10:41 AM
  #192
pizdets17
pizdets17's Avatar
Never drove on them long or fast enough until this winter. Shakes are there..
Old 03-25-11, 07:27 AM
  #193
RoboRam12
RoboRam12's Avatar
You originally just said 3 brand new sets of wheels and tires. Then you said 2 of them were from Lexus. And I'm only trying to help you out here and give you possible causes of your problem, try to not go off about it. I understand it is frustrating because you have thrown all this money at the car, but being frustrated with people trying to help you isn't going to find the problem.
If it isn't the wheels, and it isn't the tires, and it isn't the bearings or a loose steering rack, then the next thing to look at are your wheel studs. Are any of them loose, as in where they go through the hub, not the lug nuts being loose. A loose wheel stud won't hold the wheel tight against the hub, and can cause a vibration, much like loose lug nuts would.
Old 03-25-11, 10:14 AM
  #194
pizdets17
pizdets17's Avatar
Have you ever looked at a Lexus rim? If you flip it around it says toyota on it lol. Same crap. 1 set was an aftermarket Kaotic rim set ($450 a rim so not really cheap stuff) second set is OEM 16gs rims, third set is OEM 3GS rims. Whats not clear about that?
Old 03-25-11, 11:29 AM
  #195
Och
Och's Avatar
Are you using lug nuts made for that specific rim?
My suggestion, get a set of alloys from 1st gen GS/LS, as these were made from some monster alloy that even Chuck Norris couldn't bend, and see how your car rides on these.
Quick Reply: front suspension fixes and facts
