HELP! Stoptech BBK (or any BBK) Question!
I just used a local shop here that is pretty well known in the socal community. Actually, I did end up measuring the rotors, and found out that the rotors weren't cut perfectly straight.
Got the rotors turned again, and now vibration is gone. Thank Goodness. And for those that want to know the torque specs for the stoptech rotor hats, its only 6 ft lbs.. so you can pretty much hand tighten, and they should be good. The only torque wrench i could find only went down to 20 ft. lbs, so i didn't even worry with that.
Thanks to all for your help!
