Safe to run 10mm spacers with 5mm extended studs?
Old 10-23-09, 05:36 PM
PHML
Master Thread Closer!!
PHML's Avatar
I ran OEM stock studs with 5mm spacers...was good...never had any issue...just make sure you torque each lug.
I would think using 5mm studs with 10mm spacer should be ok as well.
Old 10-23-09, 05:46 PM
4play4dr
4play4dr's Avatar
i jus bought a set of 10mm spacers..so we'll see how it goes..i have the studs too jus in case i needa switch em out
Old 10-23-09, 07:43 PM
CleanS14
CleanS14's Avatar
Your stock studs only allow for a 7mm spacer to be used max. Anything more than that and you should definitely use a longer stud. When you change the studs don't forget to torque your lug nuts again after the first 10 miles.
Old 10-23-09, 07:48 PM
4play4dr
4play4dr's Avatar
ima try n slap the 10mm spacers on without the studs that come with em..i already have some extended studs from a 5mm spacer set i bought a while back on..so from what everyone is saying..i should be good
Old 10-24-09, 12:21 PM
CleanS14
CleanS14's Avatar
Ahhh yah I read wrong... thought you didn't have extended studs but that extra 5mm should be cool. Just torque the lugs.
Old 10-24-09, 02:38 PM
4play4dr
4play4dr's Avatar
yea cool..when i get em on..ill update this thread sayin if it works fine or not haha
Old 07-07-15, 03:20 PM
IS3_FTW
IS3_FTW's Avatar
Using 5mm studs good enough for 10mm spacers?
AtlantaVIP
11-15-11 11:43 AM
jnguyen87
10-15-09 02:01 PM
t0e
CL of Southern California
05-15-09 02:05 PM
Rich27
Wheels, Tires & Brakes Forum
03-31-09 11:00 AM
wongerZ
01-28-09 06:30 PM
Quick Reply: Safe to run 10mm spacers with 5mm extended studs?
