Safe to run 10mm spacers with 5mm extended studs?
Old 10-16-09, 05:53 PM
4play4dr
4play4dr's Avatar
Default Safe to run 10mm spacers with 5mm extended studs?
i have a 5mm spacer kit and i am using the extended studs they came with..but question is...can i throw on a 10mm spacer safely without changing the studs to accommodate the extra 5mm? pulled my fender a lil too much so now i need spacers to be flush again
Old 10-17-09, 10:54 AM
5t341th
5t341th's Avatar
would u want to risk it?
its like having stock studs with 5mm spacers all over again.
i'd rock it but i would be paranoid driving around
Old 10-17-09, 12:38 PM
4play4dr
4play4dr's Avatar
i guess ur right..i jus wanna kno if the lugs would tighten it enough to be safe..as im not sure how much longer the studs i have are compared to stock
Old 10-17-09, 12:49 PM
VNN326
VNN326's Avatar
test fit it. see how many times the lug turns. if its around 7 times youre good.
Old 10-17-09, 03:18 PM
pingu
pingu's Avatar
I would not. Chrispy learned the hard way.
Old 10-17-09, 06:03 PM
vwynn
vwynn's Avatar
so what happen to chrispy?
Old 10-17-09, 06:19 PM
chrispy
chrispy's Avatar
My 10mm and 15mm spacers from Ichiba have the same length studs. So maybe you can. What LOLTHXkBYE said is right. If you get 7 turns it should be fine. Make sure the wheels are hubcentric or run hubcentric rings if you run a lot of camber because that stresses the studs if they're not.
Old 10-18-09, 12:47 PM
4play4dr
4play4dr's Avatar
yea i was thinkin bout gettin some hubcentric type spacers..so that should be good..ill have to give it a shot..jus wanted to see if anyone else has done this and wanted to hear some feedback
Old 10-18-09, 02:52 PM
5t341th
5t341th's Avatar
i am using 5mm spacers with stock studs. i forgot how many turns it is though.....
Old 10-18-09, 09:30 PM
4play4dr
4play4dr's Avatar
^^how does it ride? any wobble or anything?
Old 10-18-09, 09:33 PM
chrispy
chrispy's Avatar
Rides fine until your studs break off.
I think if the 5mm spacer was hubcentric it wouldn't be as bad. But with Ichiba spacers, the 5mm spacer will be too much for the stock studs because there is no hub ring.
It's even worse when your car is low with that much camber. Just get extended studs.
Old 10-19-09, 10:46 PM
4play4dr
4play4dr's Avatar
okay..so ur saying i should go for the extended studs that come with the 10mm spacers?? cuz right now im using the extended studs that came with my 5mm set..im sure the 10mm studs would be the best thing..im jus too lazy to knock out the old ones and put in the new..jus wanna kno if it'll work fine without replacing the studs
Old 10-19-09, 10:55 PM
chrispy
chrispy's Avatar
Yeah. Well how much extra thread do you have on those extended studs? Subtract 5mm from it and see if it's enough. It depends on your wheels too.
Old 10-19-09, 11:01 PM
4play4dr
4play4dr's Avatar
ill check it out over the weekend..i think ima jus get teh spacers and studs anyway..jus wanna go the easy route..if it doesnt work..i guess ill have to swap studs
Old 10-20-09, 12:08 AM
5t341th
5t341th's Avatar
nah no wobbles. its 5mm ichiba's. they are hubcentric too.
but anyway, since u got the studs, just replace em.
like 15 min job per wheel.
Quick Reply: Safe to run 10mm spacers with 5mm extended studs?
