i think i want break kit.. what to get?
Hey guys i think its time for a break kit
any idea what i can get for around 1k give or take?
let me know asap![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
thanks
Erick G
let me know asap
thanks
Erick G
erick you can get the TRD or the supra brakes for that price, Im not sure if the brembo is in your price range I think there between 1.5k-2k, if you are going to use forced indction in the future I would suggest you save up some more $ and get a brembo or HP racing kit
The Supra TT BRAKE (not "Break"!) kit is the most cost effective solution....but if you want to get into the "big leagues", AP/Brembo can't be beat. If you want something a little more exotic, you can look at the Endless 4 or 6 piston setup also. More pricey than the AP or Brembo setup however...
That depends on your off-set of the rim...if you know of anybody that has the supra tt brakes, ask the guy to help you out to see if your rims will clear the calipar...that's what I did with my rims, I was lucky that HI98GS has the supra tt set up on his car, saved me from a lot of headaches, for me I know that I have to go with OEM size rotors and calipar's...
Aloha
Aloha
Erick,
Hit this link below for the Supra kit that Steve Ganz @ Carson is selling.. This is my next purchase and Steve tells me he can get the rotors in slotted and drilled if I wish or just slotted or just drilled.. So lots of options to choose from rotor wise..
Shoot him a PM SUPRATRD or email him at gonzo4u@earthlink.net and he should be able to hook you up..
Supra Brake Upgrade Link
It doesn't only depend on offset, it also depends on whether the rims are 'high disc' fitment. Basically if you don't have more than 2" between the back side of the spoke and the caliper, you can't fit a bigger brake upgrade.
