Megan LR Coilovers, Camber Adjustment
Old 11-09-09, 12:05 PM
gman44116
gman44116's Avatar
Default Megan LR Coilovers, Camber Adjustment
Megans website on the 2GS coilovers states: "Pillow Ball upper mounts for camber correction" in the description on their website. Is this correct?
Can any Megan owners confirm this for a 2GS please.
I plan on dropping 2"-2 1/2" and need to know if I will have camber issues with my winter 16"s and summer 18"s....before I order...
Old 11-09-09, 12:31 PM
GSteg
GSteg's Avatar
It doesn't work for our cars. We don't utilize struts.
Old 11-09-09, 12:42 PM
gman44116
gman44116's Avatar
Will I require a camber kit to keep my tires wearing evenly with the drop and tires I want to have??
Old 11-09-09, 01:17 PM
GS300ToM
GS300ToM's Avatar
no u wont need it since your not gonna be super dump.. rolling on stocks, 17-20 wheels? but for the front RCA would def help a bit... just put your toe into spec and that shud save u some tire wear
Old 11-09-09, 01:32 PM
GSteg
GSteg's Avatar
2-2.5" isn't crazy low at all so you should be okay as long as your toe is fine. Camber just wears one side more than the other. If you can't rotate/flip your tires, then I would definitely invest in some RCAs. The amount of tire you save will eventually pay for the RCAs.
Old 11-09-09, 04:10 PM
gman44116
gman44116's Avatar
Any suggestion in regards to wheel spacers? I am planning on 245/40/18 on 8x18 for the summer and ugghh, the stock 225/55/16 on 16x7 for my winter setup...
Don't want to be too aggressive just not sure what these two wheel/rim setups will look like without spacers...
right now stock they are so much inside I cringe at the thought of what the 16's will look like with the megans...
Old 11-09-09, 10:10 PM
GS300ToM
GS300ToM's Avatar
if your tryna go for a flush look then give us the offset and we can go from there
Old 12-01-09, 01:19 PM
MDSC
MDSC's Avatar
is there any coilover out there that has camber adjustments?
Old 12-01-09, 03:17 PM
5t341th
5t341th's Avatar
not for our cars. we dont use a mcpherson design.
even if it did have camber plates, it wont do anything
Old 12-02-09, 11:57 AM
CircuitMS
CircuitMS's Avatar
SPC makes adjustable front arms for adjusting camber and caster. They also have rear camber bolts.
Feel free to PM us for pricing or info.
Old 12-02-09, 12:18 PM
gskidd
gskidd's Avatar
im going to get some megan coilovers this weekend and im going to slam my car im on stock wheel but i was wondering if anyone had any suggestions for what size spacers would look good and somewhat flush
Old 12-02-09, 01:24 PM
5t341th
5t341th's Avatar
50mm spacers
Old 12-02-09, 02:27 PM
GSJake
GSJake's Avatar
Originally Posted by 5t341th
50mm spacers
LOL... I know you are joking!
The largest I have seen are the project kics 30MM, but if you must go that big put that cash toward new wheels.
Old 12-02-09, 03:23 PM
5t341th
5t341th's Avatar
he can just stack them onto each other
Old 12-03-09, 09:58 PM
gskidd
gskidd's Avatar
Smile
thanks for the suggestions hopefully ill have pics this weekend with my new suspension
jgr7
Suspension and Brakes
12-23-13 09:25 PM
kenTHUNDER
12-21-13 08:06 PM
Mrbanhbao
42
04-18-12 11:09 PM
stancedIS
07-26-11 06:29 PM
mikesblkgs
13
04-14-09 10:44 AM
Quick Reply: Megan LR Coilovers, Camber Adjustment
