OEM Lower Control Arm No.2 related thread
If you got Daizen issues, GTFO.
jk, go to...
skperformance's "front suspension fixes and facts" thread
THIS THREAD IS INFORMATION REGARDING OEM LOWER CONTROL ARM NO2
Definition
Lower Control Arm No.2 is sometimes (usually
) referred to as "tension rod"
Issue
Bushing in tension rod wears out as you drive, espeically on lowered car. Please refer to the link above for common symptoms and diagnostics.
Available Solutions
1) Get Daizen polyurethane kit. For information relating to this kit regarding the tension rod, please refer to the thread above.
2) Replace with tension rod with matching year arm.
3) If you have a 98-00 or 01-03, replace with 03-05 for beefier bushing.
4) get heim joint (which would be awesome)
Below is a comparison between 98-00 and 03-05 tension rods.
![](http://homepage2.nifty.com/paris/parts_2006/parts_002_02.jpg)
and you can see clearly the deterioration of the bushing and difference in size of the arm itself and bushing in my post here. I have successfully installed 03-05 tension rods on my USDM 98-00 GS.
Premises
98-00 have a skinnier arm
00-03 have the beefier arm (confirmed by gman44116)
03-05 have the beefier arm & TRD equivalent bushing
Part Number
These SHOULD be the same for the NA Lexus dealerships also. But please check before you order.
Source: ClubAristo.net
JZS16x 03.01~
●Front Suspension Lower Arm No.2 RH(48660-30281)
●Front Suspension Lower Arm No.2 LH(48670-30281)
PLEASE CONFIRM THIS PART NUMBER
JZS16x 99.08~03.01
●Front Suspension Lower Arm No.2 RH(48660-30280)
●Front Suspension Lower Arm No.2 LH(48670-30280)
JZS16x 97.08~99.08
●Front Suspension Lower Arm No.2 RH(48660-30240)
●Front Suspension Lower Arm No.2 LH(48670-30240)
My Proposed Solution
Install 03-05 caster arms
Advantage/Disadvantage vs Daizen kit
Advantage:
No pressing in/out the bushing. Takes out the hassle of having to press it out and have the Daizen kit pressed in. Sure you can burn them out but I really didn't feel comfortable heating up a metal arm thats so critical. Replacing the arm itself makes it a weekend job.
Disadvantage:
1. the "feel". Even though the 03-05 arms are supposed to have TRD equivalent bushings, it's probably not as firm as the Daizen polyurethane bushing. So you will lose the "feel" (if you will). However, if your bushings are torn, should be a huge improvement anyways.
2. cost. I hate how Lexus marks up things. These arms cost about 50 bucks/side in Japan (assuming 1USD=100yen). I think they retail north of 250USD here in the States.
Note
All the OEM caster arm should have the bushings already pressed in if you buy Genuine Toyota parts. I researched the **** out of this, even went as far as calling TRD (originally to confirm the compatibility of TRD bushings with our GSs) in Japan myself to confirm but they kept on saying that they can't confirm jack for anything Lexus.
I believe the 03-05 tension rods you can buy from the Lexus dealerships here in NA have TRD equivalent bushings pressed in already as well because if you go to TRD Japan's site, it says that 03-05 S16x already has them and if I remember correctly, the parts number are the same between Lexus dealerships in the States and Netz Toyota Japan.
SO, I'm just cross-referencing from information I gathered from the internet, TRD, and local Lexus dealerships.
I'll leave it up to you to confirm anything I wrote b/c I may easily be wrong.
Installation
Open to update.
jk, go to...
Definition
Issue
Available Solutions
Premises
Part Number
JZS16x 03.01~
JZS16x 99.08~03.01
JZS16x 97.08~99.08
Advantage:
Disadvantage:
Note
Installation
Open to update.
jk, go to...
Definition
Issue
Solution
Premises
00-03 have the beefier arm (I think? not sure...can't confirm...can anyone chime?)
48660-30280/48670-30280
Part Number
JZS16x 03.01~
JZS16x 99.08~03.01
JZS16x 97.08~99.08
All these have the bushings already pressed in if you buy Genuine Toyota parts. I researched the **** out of this, even went as far as calling TRD (originally to confirm the compatibility of TRD bushings with our GSs) in Japan myself to confirm but they kept on saying that they can't confirm jack for anything Lexus.
SO, I'm just cross-referencing from information I gathered from the internet, TRD, and local Lexus dealerships. I'll leave it up to you to confirm these parts number for final confirmation b/c I may as well be easily be wrong.
Installation
Open to update.
jk, go to...
Definition
Issue
Solution
Premises
Part Number
JZS16x 03.01~
JZS16x 99.08~03.01
JZS16x 97.08~99.08
Installation
Open to update.
Sewell doesnt have any either.. Are these the right numbers for 03-05 arms?
It's these...
they updated the part number it seems... I've just bought it from carson
unknown, YET.. but it's gonna be from UPS ground.
260.56USD from carson without shipping.
In Canada, it's 318 CND PER ARM
and update on my bushings from TM, I've got an Email today that it's been prepared for shippingvia USPS, only that I've already ordered the arms..... SOOOOO I'll have a set of bushings for sale later on...
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
me too lol
and update on my bushings from TM, I've got an Email today that it's been prepared for shippingvia USPS, only that I've already ordered the arms..... SOOOOO I'll have a set of bushings for sale later on...![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Hey OP, did you mean to say that the 30281's are the ones with the TRD bushing. Your info is conflicting. It shows that the 30280's were not in production 03-05 and the 30281's were? Thanks so much for the research you have done on this, its going to help alot of people!
30280 were replaced by 30281.. basically they updated the part number or updated the part itself as in maybe they changed the manufacturer on them... it happens often in parts for cars...
So by the looks of the part number wise, they originally had 00-02 (mid gen 2GS) using a updated version of the arm, then they updated again in 03... then they don't make 00-02 anymore and since (it seemed like) 03+ fits into 00-02, they just used that instead.
