ASC ABS and ASC OFF come on after changing lower control arm n brake
need help guy...my ASC ABS and ASC OFF light come on after i change my brake and lower control arm. I try pressing the the ASC buttom nothing...what happening here?
did you disconnect a wheel speed sensor? if so make sure you reconnected it. did any of the wires on the wheel speed sensor get stretched or anything like that? if so check for damage.
i let it hang for like couple of sec. resting on a jack. pretty sure it was enough to demage it...if it is i know what the problem. Those three light mean that sensor is no good? I check the wiring there was no demage to it.
check behind the rotor, there the brake line to the brake calipers and there another line (wire) to the center to the rotor(in the back), that's the sensor. i dont know how to import pic. still working on it
