Daizen DIY
Old 12-22-10, 01:57 PM
  #121
vwynn
vwynn's Avatar
Originally Posted by pizdets17
Mine moves freely with no force needed...
Originally Posted by JiBBeL
Ya, the Daizen bushing was so much beefier than OEM, I didn't even think it was gonna fit. I got it in alright though with some wiggling and force. Once in, it's a tight squeeze and will require pressure to move it up/down. Nice tight handling =)
hmm so we have one person that moves freely.. and one that requires some force.. LOL... and mine requires lots of force... dam i think somethings wrong with mine.
Old 12-22-10, 02:04 PM
  #122
sakataj
sakataj's Avatar
YEAH....operator error hehehe
  #123
vwynn
vwynn's Avatar
LOL i didnt install it tho . bought the car with it hahhahaha hmm.. wonder if i should check it or just leave it be...
Old 12-22-10, 03:54 PM
  #124
Bon
Bon's Avatar
My UCA moves easily up-and-down but doesn't just fall on its own weight. The metal bushings within the polyurethane need to be lubricated where they contact the polyurethane. I even loaded extra lube between in the small void between the bushing pairs to serve as a reservoir for the steel sleeve. The polyurethane needs to be lubricated on the ends where it contacts the frame. The lubrication on the ends made mine slip right into their mounting location without much wiggling or bumping.
Old 12-22-10, 11:43 PM
  #125
krazyGs3
krazyGs3's Avatar
I have a 05 gs300... I just want to know if any body is going to replace the caster arm or front rear lower arm or lower arm #2 bushing.... can you measure the size of the hole of the arm??? i have a set of bushings from my honda... just want to see if there about the same size.. thanks..
Old 12-23-10, 06:16 PM
  #126
TLcoats
TLcoats's Avatar
Haha dude. I highly doubt your honda bushing isn't going to fit. Just order a Daizen set from TM.
Old 12-23-10, 07:51 PM
  #127
vwynn
vwynn's Avatar
dont you mean.. "I highly doubt your honda bushing is going to fit"
lol
Old 12-23-10, 10:16 PM
  #128
TLcoats
TLcoats's Avatar
lol
Haha. Yes exactly that's what i men't by that. Keep in mind though i was extremely hungover with two hours of sleep when i wrote that.
Old 12-23-10, 10:27 PM
  #129
ThomasGS4
ThomasGS4's Avatar
It was only 6pm in the evening...?
Old 12-23-10, 11:38 PM
  #130
TLcoats
TLcoats's Avatar
Haha. That's what happens when you party like you're a teenager the night before...
Old 12-24-10, 11:14 AM
  #131
krazyGs3
krazyGs3's Avatar
It's a rear trailing arm bushing. It's as big as a baseball. Since I have them.
Old 03-06-11, 10:52 AM
  #132
MHowerton1
MHowerton1's Avatar
Default Daizen Bushings
thanks for the great writeup and photos, they were a great help - just finished installing the Daizen kit in my GS300 '01. I did run into one snag - caster adjusting bolts had siezed in the bushing sleaves and had to cut them out. (new Bolts from Sewell were $16 each) Also did wheel bearings and seals while I had everything out. (one shop said bearings were bad - 130,000 miles - but turned out bearings looked great) I did have 4 loose balljoints however. I would highly recommend replacing both upper and lower balljoints while you have everything apart if your mileage is over 90 - 100,000.
Old 01-18-17, 11:52 AM
  #133
pinoiryder
pinoiryder's Avatar
i know the thread is old but anyone know where to get the bushing? any link or know someone is selling one?
Old 01-19-17, 10:42 PM
  #134
lexo98
lexo98's Avatar
dont even try to find these. Go to the figs engineering website
mad_trbo
GS - 1st Gen (1993-1997)
14
08-29-23 03:43 PM
Pensioner2
09-21-22 10:08 AM
Jeffrimerm
Suspension and Brakes
07-01-15 12:47 PM
NEbiker10
11-29-12 05:01 PM
Quick Reply: Daizen DIY
