Simple Brakes Question
definitely want a breaker bar...
and turn the steering to the opposite side to give yourself room.
torque down to 95-100lb
also the short sockets wont clear so youll need an extension or a longer socket.
For the front, you need to remove 2 14mm bolts for the caliper, and 2 17mm bolts for the caliper bracket. If you are replacing the rotors, hit them really hard with a strong hammer multiple times before disassembly. That way they will easily come off when you take your caliper bracket off
