hub-rings - are they necessary?
F is for Fraud
They are not necessary but you might get vibrations if you do not use them. Hubcentric rings will keep your wheel centered, so when you put your lug nuts on, they will be perfectly centered. An uncentered lug nut is what causes the vibrations.
I didn't use them on my Integra and after about a year I had serious vibrations. After further inspection, I found that all my wheel bearings were toast(and a PITA to change). Without the rings it puts alot of stress on the bearings which causes them to wear out super fast.
Master Thread Closer!!
not required...but highly recommended.
they basically ensure you mount your aftermarket wheels in the center of the hub...if not...vibration will occur.
its fairly inexpensive...under $20 for a set of 4 plastic ...shipped. i bought them for every wheel i've owned....won't mount any wheel without hubcentric rings.
pete
pete
pete
pete
I buy my rims used, i do not see a purpose in buying new, paying a premium, when i simply get new rims the next year.
And, to my knowledge, a lot of manufacturer's of aftermarket rims will still use a generic center bore on multi-fit rims, and oftentimes than not with 200$ or 2000$ rims you still need to use hubcentric rings.
Another reason to not ignore the vibrations, is that these vibrations do create 'flat spots' on the tires and cause uneven wear to a certain extent. Personally i buy them right away, just to not have to endure more than 5 mins of the annoying vibration.
True, but come on, what are the chances of you coming across that??
