Sway Bars
I have Daizens...flattened the car out around curves quite a bit and kept a very nice ride...but I'd be interested driving a car with TRD blues (stiffer than Daizens).
Never had a squeak with my poly bushings, but I lubed 'em like no tomorrow when I put em on a year ago!
The key is to lube them very well. There is a point of diminishing return when it comes to lubing. It gets to the point where you can only stuff so much grease between the bar and the bushing that excess grease will be pushed out. Mine got a bit dry after a while, hence the squeak. Someone on here integrated a grease fitting to make greasing easier. A small hole in the bushing will probably not affect the strength of the bushing too much so you might want to look into it. I would have been happy if Daizen created a few small grooves to channel the grease.
Well lets just say that when I had my Daizen with Ltuned springs, they rode rougher than my friend's Tanabe springs with TRD sways, and his car handled flatter in the corner.
I went from TRD to Daizen because I thought being able to adjust the rear link was a neat idea. I started off with the softest setting and it was definitely noticeable in the amount of body roll gained. Eventually I went to the middle setting and it's still had more roll than the TRDs. Before I sold the bar, I switched to the stiffest setting Daizen had to offer. Still more body roll than with the TRD and the ride quality wasn't any better. On rough roads, you could definitely tell the ride was kind of harsh. With the TRDs, they felt more 'firm' instead of harsh. It's been a few years since I had the bars but I would say the Daizens were much more comfortable. It's probably true on the softest setting but you sacrifice handling quite a bit. Downside to the TRD is that they cost more.
