LS400 Calipers
Old 12-17-09, 04:34 PM
ak11
ak11's Avatar
Default LS400 Calipers
I am about to install a set of LS400 calipers and just have 2 quick questions:
Does Sage Front RCAs need perfect fit without cutting the threat?
Will a 15mm spacer fit my stock 17" rims?
Thanks!
Old 12-17-09, 09:11 PM
GSteg
GSteg's Avatar
You will find probably 30 threads on this topic alone.
1. No need to cut anything once you have RCAs. The sage are thick enough that the calipers will clear the tie rod.
2. 15mm spacers is enough to clear the OEM 17s.
Old 12-18-09, 04:48 PM
PHML
Master Thread Closer!!
PHML's Avatar
SAGE front RCA is 30mm thick...no shaving required.
15mm spacer gives plenty of room.
Old 12-19-09, 03:10 PM
tom steele
tom steele's Avatar
just get bigger rims screw the spacers!
Old 12-19-09, 03:51 PM
ak11
ak11's Avatar
Just read too many threads and got a little confused
Thanks guys for replying!!!
GSGenesis
Suspension and Brakes
07-31-14 06:46 AM
sleepingbe
12-07-13 09:39 PM
bryan767
23
05-12-11 05:06 AM
zazzn
GS - 1st Gen (1993-1997)
13
03-04-08 03:29 PM
mjr24
Wheels, Tires & Brakes Forum
04-28-04 07:07 PM
Quick Reply: LS400 Calipers
