97-00 Control Arm Bushings
I purchased a 92-96 Prothane bushing set. The front lower arm bushing fits with no issue.
The rear bushing does not fit into the sleeve. You will need to take a dremel and trim the sleeve opening so the bushing can slide in.
It was straightforward, unsure why the sleeves are different between the years.
hey man i am a lexus tech and my bushings are worn out but instead of putting the polli bushings in i am getting the supra front lower control arms instead they are supposed to feel a lot more crisp then the original factory arms as i am into cornering and of course speed (only on the track though) they only cost about $350.00 each side
Sorry to revive an old thread but I am currently trying to replace the bushings on my 97 SC300 and can't get the two piece poly bushings installed because of the sleeve with the oblong opening on the one side. If I cut both the inside part of the sleeve (with the oblong opening) as well as the lip the width would be too narrow so I am thinking that I need to cut the inside section but leaving the lip, do you have any tips or recommendations on how to get this done? Thank you in advance and again sorry for reviving a dead thread
EUROJulian
Suspension and Brakes
82
05-31-04 12:55 PM
