Supra TT 4pod brake caliper VS 95-00 LS400 4pod brake caliper, DIFFERENCE?
#61
so yeah, i got my hands on another ls400 passenger caliper.
and here are the rest of the pics before the original ls400 caliper decided to blow.
98-05 GS Brembo Slotted rotor on the left, EBC slotted dimpled 95-00 ls400 rotor on the right
Dust shield before cutting
After trimming, i ended up trimming even more off where the tie rod was.
Rotor is on, using the lugs to hold it in place as i put the caliper on
Caliper is on
Caliper is on
#62
Master Thread Closer!!
I just did mines today....but I started by painting the rear calipers to match the LS400 calipers, installed goodridge ss lines (all 4 stock lines were frozen...pb blaster helped a bit), installed front H&R 15mm spacer with new extended studs (I couldn't use my project kics cuz my wheels didn't have the inset spacing for the protruding studs...also my front wheels are not BBK-friendly), installed new front cross-drilled rotors and LS400 calipers (had to modify the rotor shield a bit), then I couldn't find my anti-squeal lube for the new brake pads (had to go to Checkers to buy a new one), and finally bled all 4 corners (thanks to my neighbor's kids...one did the pumping and other other checked the brake fluid reservoir). Oh...and cleaned up the garage....my tools were everywhere....wifey liked seeing a garage she can walk in....LOL!!! Took it for a test drive tonight....feels good....no spongy feel.
#64
I know back from dead thread lol. I don't get why everyone goes with ls400 over supra TT set up? My TT calipers are lighter then my GS ones plus TT rotors are 1/2" bigger and to me look better being smooth. Plus I got mine from rock auto $220 shipping and core included for both sides
Ryeno
SC- 1st Gen (1992-2000)
27
05-26-10 05:00 PM
swat1727
Suspension and Brakes
08-06-08 05:00 PM
TimsR1
01-31-07 07:16 PM
VSsc400
58
11-12-03 08:37 PM
