best/easiest way to remove a frozen caliper pin
anyone have had to remove a frozen caliper pin? how did you do it? the lower pin on my front driver side caliper is not moving. i'm going to try to spray pb blaster into the boot and pin to see if i can loosen and replace it tomorrow.
let me know.
let me know.
i recommend using Freeze off, a wrench and a big flat head screw driver. first spray the freeze off(this stuff works very well especially when removing exhaust bolt and o2 sensor). use your wrench and work it up and down alittle at a time and at the same time use your flat head try to pry it away from caliper.this process worked for me.
