help adjusting coilovers
when you lock the coilovers does the bottom ring screws all the way up or locks at the bottom? in the picture you can see three gold rings does all three rings meet up at the top or 2 at the top and one at the bottom? thanks for the help guys!
http://i2.photobucket.com/albums/y12...7/IMG_1017.jpg
It's easy. Just loosen the lower perches and then lower the upper perches if you want to lower your car. Then after you find your desired height, tighten the lower perch and your done.
Also, the drivers side sits lower than the passenger side.
hahaha ahhhh having trouble lowering it...
Dat yeahhh i did man thanks alot here is pic before the drop crappy iphone pic... but will add new pics once the drop is done
lol!! having trouble with the DRIVER SIDE!!! the strut/shock assembly doesnt want to come off.. im running 225/35/19 and 245/35/19. finished all the other sides just need the driver side any tips on getting out the driver side assembly? it doesnt seem to come out the same way seems to be stuck inside the groove
MIKU*SC3
Suspension and Brakes
05-20-12 12:07 AM
GeorgeGS4
Wheels, Tires & Brakes Forum
12
07-26-05 07:34 PM
