HELP! Rear UCA REinstall nightmare!
For those of you that have removed your rear UCA's and replaced the bushings... How did you get the nuts back on the bolts without dropping the subframe?
Any secrets???
Any secrets???
Yes i read the sticky, but there was no information regarding getting the nuts back on there... it's a really hard to reach spot.
I also posted here so that it would be seen.
But what about the C clips? The C clip blocks the nut from being able to be put on a wrench. It's all insanely hard to reach back there, I have no idea how this is going to work
I changed mine without dropping the subframe.
It is tight but doable.
I believe I separated the nut and c-clip( sorry gettin old, CRS)
I did not experience the difficulty in the sticky.
Not much rust to contend with.
Alan
Alan
Yea, i have a southern car (louisiana). No rust at all! bolts broke loose easy!
Anyway, I have decided to just drop the entire subframe, Installing a TT diff and powered by max subframe and diff collars. just doing it all at once
yauser
SC- 1st Gen (1992-2000)
08-20-09 09:17 AM
