RCA question
Old 02-04-10, 11:16 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Default RCA question
Are RCA required to run LS400 BBK setup and all BBK like Rotora, brembo etc.. .. I thought that RCA were only for really lowered cars.. THanks
Old 02-04-10, 11:38 AM
GSteg
GSteg's Avatar
It's not required for the LS400 brakes. Alternatively, you can shave off a bit of the tie rods' threads. RCAs just happens to work if you dont' want to do any shaving. I don't ever recall anyone needed RCAs to fit other brakes setup though, just the LS400. In any case, i'm running 0.5" RCAs and the caliper barely clears.
Old 02-04-10, 03:13 PM
tmf2004
tmf2004's Avatar
Thanks Henry.... So your 0.5'' lower.. I'm not sure why this is needed for the brakes
Old 02-04-10, 04:09 PM
GSteg
GSteg's Avatar
Because without it, the LS400 calipers will hit the tie rod bolt. When you add in RCAs, you're essentially adding more clearance.
Old 02-04-10, 05:02 PM
PHML
Master Thread Closer!!
PHML's Avatar
well...the RCA is also suppose to correct "suspension geometry" for lowered vehicles....which may be the reason for early lower ball joint problems.
Old 02-04-10, 05:08 PM
GSteg
GSteg's Avatar
Yup! The added clearance is just an added bonus for those who want LS400 calipers
huss11
10-24-18 09:39 AM
shaodome
Florida Lexus Club
09-01-09 07:22 PM
rustednail
Suspension and Brakes
20
04-19-09 12:38 AM
Rhabryn
03-03-03 10:36 AM
Quick Reply: RCA question
