F-Sport brake pads. Where to buy?
Old 02-09-10 | 02:28 PM
Sunspyre's Avatar
Sunspyre
Default F-Sport brake pads. Where to buy?
I've looked all over and can't find anybody selling the brake pads for the F-Sport brakes besides the dealer.
Are there any other manufacturers of this part or am I going to have to go through the dealership for this?
Thanks in advance for replies.
Edit:
Front Pads ST-60:
http://store.zeckhausen.com/catalog/...p?cPath=24_412
Rear Pads ST-40:
http://store.zeckhausen.com/catalog/...p?cPath=24_411
Front Rotor Rings 355x32:
http://store.zeckhausen.com/catalog/...ath=24_212_511
Rear Rotor Rings 345x28:
http://store.zeckhausen.com/catalog/...ath=24_212_510
Keep in mind that the cheapest ones on that page work great. You don't need the expensive $300+ ones for normal street applications. In fact, it's probably worse to use that sort of compound for regular street driving.
Old 02-09-10 | 06:50 PM
javyLSU's Avatar
javyLSU
2IS OG
No one is going to sell "F-Sport brake pads," except Lexus dealerships. Search for brake pads that fit StopTech ST-60 calipers for the fronts and ST-40 calipers for the rear. Good luck!
Javier
Old 02-09-10 | 07:01 PM
quang's Avatar
quang
Sounds like an expensive upgrade and maintenance afterward.
Old 02-09-10 | 11:30 PM
someboy's Avatar
someboy
i tried just buying the F sport rotors from lexus, they cost $1000 dollar each rotor. so good luck on the brake pad.....
Old 02-10-10 | 01:02 AM
javyLSU's Avatar
javyLSU
2IS OG
There are a few reasons to upgrade to a BBK; saving money is not one of them.
You don't have to buy the entire rotor when they wear out. Since it's a two-piece disc, you only need to replace the friction rings (and fastening hardware) when the disc thickness reaches minimum. Should run approximately $275 each.
Javier
Old 02-10-10 | 10:14 AM
Sunspyre's Avatar
Sunspyre
Thanks a lot for the replies.
I kinda figured the calipers had a different name, but I had no idea what it was.
I'll keep an eye out for those pads and not looking forward to replacing them!
For searching reference:
Here is a list of manufacturer's part numbers that will fit our ST-60 caliper (X denotes pad compound):
Ferodo: 11 FRP3054X-N
Hawk Performance: HB122X.710
Performance Friction: 7793.XX.18.44
Pagid: E1903 XXX 010
Note the number represents the SHAPE of the pad, NOT the compound. The complete part number for specific compounds will vary, but the numbers above will be part of each. The letter "X" represents the portion of the number you'll need to fill in for the compound.
Old 02-17-10 | 11:26 AM
g_abac's Avatar
g_abac
I bought Performance Friction 1038 PADS to replace the pads that come with F-Sport BBK.
The part number of pad are the same that using on ST-60 for front and ST-40 for rear.
1 x PFC1038 high performance brake pads - StopTech ST-60 caliper (D1247) [1 box required] (63-700-1247) = $175.00
1 x PFC1038 high performance brake pads - StopTech ST-40 caliper (D609/D372) [1 box required] (63-700-0609) = $159.00
You can buy them online
ST-60 PADS
http://store.zeckhausen.com/catalog/...ed7ol5eqli7rj6
ST-40 PADS
evident
11-12-15 02:56 AM
ChuH
12-19-14 01:11 PM
gs2isf
10-30-13 11:25 AM
g_abac
Suspension and Brakes
05-23-09 09:23 PM
DaKi3241
05-23-09 10:42 AM
